7i52s replaced ic pin continuity question
- 3D-Master
- Thank you received: 5
14 Nov 2020 11:33 #189351
by 3D-Master
Replied by 3D-Master on topic 7i52s replaced ic pin continuity question
i believe i found the error.
the 50 pin ribbon cable has no connection on one of the connectors, so probably recrimping the cable will work
- 3D-Master
14 Nov 2020 11:52 - 14 Nov 2020 12:20 #189353
by 3D-Master
yes now everything works
i believe when i unplugged the 7i52s i pulled the cable in a wrong way which may have ripped the cable inside the ribbon
thanks for your help!
Last edit: 14 Nov 2020 12:20 by 3D-Master.
Time to create page: 0.071 seconds
