7i95 installing
- Achim1966
19 Nov 2020 13:06 #189803
by Achim1966
7i95 installing was created by Achim1966
I once needed help installing a Mesa 7i95.
I don't know anything about Linux at all.
I managed to install Linuxcnc 2.9 master after reading a lot.
I am using Linuxcnc PNCconf Wizard to configure the Mesa Card.
By the "Discovery Option" i read the Mesa 7i95 Data from Card? Is this corect?
If starting Linuxcnc i get an error for watchdog 7i96?
Please take a look at the error.
Thank you in advance for your effort
Greatings Achim
Greatings Achim
- Thank you received: 7506
19 Nov 2020 13:08 #189805
Replied by tommylight on topic 7i95 installing
Error ?
- Achim1966
19 Nov 2020 13:13 #189806
by Achim1966
Replied by Achim1966 on topic 7i95 installing
parameter or pin ´hm2_7i96.0.watchdog.timeout_ns´ not found
- Thank you received: 5337
19 Nov 2020 13:19 #189808
Replied by PCW on topic 7i95 installing
You would need to replace all instances of "7i96" with "7i95" in the hal/ini files
- Achim1966
19 Nov 2020 13:28 #189809
by Achim1966
i take a look in the (mesa_7i95.hal)
in Line
15 addf hm2_7i96.0.read servo-thread
i must chage it in
15 addf hm2_7i95.0.read servo-thread
is this the right way to do?
in Line
i must chage it in
19 Nov 2020 13:42 #189810
Well, I would do it globally with the editor.
19 Nov 2020 13:51 #189811
In the text editor, "search and replace" or CTRL+H
- Achim1966
19 Nov 2020 14:16 #189814
by Achim1966
o.k.
i do that and i can start linuxcnc.
Thank you . That was easy .
- Achim1966
19 Nov 2020 15:16 #189818
by Achim1966
the LED Documentation from the the 7i95 is ???.
My LED green
CR 1 off
CR 2 on
CR 3 on
CR 4 on
CR 19 on (Red) (INIT)
CR 20 ? ( off) Done
CR 21 On ( Yellow) PWR
The documentation writes something from CR11 and CR12 ????
My LED green
CR 1 off
CR 2 on
CR 3 on
CR 4 on
CR 20 ? ( off) Done
19 Nov 2020 15:48 #189819
The text in the manual is wrong (the table is correct)
CR11 should be CR19
CR12 should be CR20
CR11 should be CR19
CR12 should be CR20
Time to create page: 0.245 seconds
