Help configuring DM542A drivers
  • txtrone
  • txtrone's Avatar Topic Author
  • Platinum Member
  • Platinum Member
01 Dec 2020 20:42 - 01 Dec 2020 20:44 #190825 by txtrone
Replied by txtrone on topic Help configuring DM542A drivers
Just looking at one of my drives.
I thought I saw you had a 3.5 amp motor so I would set SW1,SW2,SW3 for 3.32 amps peak (OFF,ON,OFF)
SW4 off to enable less current when idle.
Ok, so I should use peak but on the lower side of my motor's power rating. Is SW4 the 'brakes' or holding power that keeps the motor locked up when not in motion?
I would not go too high with the microstepping to start with. Probably start at 2000 (10x microstep) SW5 Off, SW6 & SW7 On, SW8 Off
Ok, this is where I am getting confused. I follow you on the setup for dip switches 5 - 8 Off-On-On-Off is 2000 according to the chart on the driver. How do I then figure out Step On-Time, Step Space, Dir Hold Dir Setup in the software? I am missing the formula that gets from 2000 pulse/rev = 10x microstep ... I am sure this is simple, but I am not wrapping my head around it yet.
Are you using a parallel port or a mesa card?
Mesa 7i76e connected via ethernet cable to my PC.
Last edit: 01 Dec 2020 20:44 by txtrone. Reason: Clarification
01 Dec 2020 21:29 #190834 by rodw
Replied by rodw on topic Help configuring DM542A drivers
Yes when the motor is not moving reducing the current stops it from running hot.
So a standard stepper is 200 steps per rev (1.8 degrees) 200 X 10 = 2000
The microstepping just affects the number of steps per device unit (mm or inches)
So If you change your microstepping from 10x to say 20x , you must double the STEP_SCALE to keep it proportional
The settings are in your ini file per joint but as stated earlier, don't use my setting straight away. Start much higher.
# these are in nanoseconds
DIRSETUP = 500
DIRHOLD = 500
STEPLEN = 1500
STEPSPACE = 1500
STEP_SCALE = 261.130715645 (steps/mm)
Moderators: PCW, jmelson
Time to create page: 0.222 seconds
