7i97 Power Connection Question
- Thank you received: 5291
09 Jan 2021 20:50 #194644
Replied by PCW on topic 7i97 Power Connection Question
If it wont start below 5.2V that means there an issue with the power supply current limit or impedance. It will start at 4V if the power supply is stiff
- Mike_Eitel
- Thank you received: 183
10 Jan 2021 08:33 #194693
by Mike_Eitel
Replied by Mike_Eitel on topic 7i97 Power Connection Question
Hi pcw
What do you think of having always an elco plus ceramic parallel to the bornes?
10 Jan 2021 16:15 #194738
You could but a normal stiff power supply should work fine
(The 7I95s are tested with a normal USB supply)
- anfänger
- Thank you received: 256
10 Jan 2021 20:54 #194778
by anfänger
Replied by anfänger on topic 7i97 Power Connection Question
I had tried two different usb power supplies before I fetched my big one. This had no trouble with my setup for the mill. And there I used a7i92 7i77 7i74 7i70 and 7i71. Anyway it’s working now and I know what to do if the power supply in the lathe has troubles starting the card.
Time to create page: 0.096 seconds
