Installing the 7i96 Configuration Tool
- Ewok2
21 Jan 2021 21:59 #196153
by Ewok2
Installing the 7i96 Configuration Tool was created by Ewok2
Hello
2 years ago I use this wonderfull tools.
Now I have buy a spindle which is manageble by the 7I96 MESA card (0-10V input)
I have a debian stech with LinuxCnc2.8
I have try to install the latest version either with "sudo python3 setup.py install" or installing the deb package but I get 3 error durring install...
File "build/bdist.linux-i686/egg/c7i96/c7i96.py", line 307
self.maxVelocityLbl.setText(f'{fpm} IPM')
SyntaxError: invalid syntax
File "build/bdist.linux-i686/egg/c7i96/card-broken.py", line 10
command = f"mesaflash --device 7i96 --addr {ipAddress} --readhmid"
File "/usr/local/lib/python3.5/dist-packages/c7i96-1.2.2-py3.5.egg/c7i96/card-broken.py", line 10
any idea to solve the pb?
- BigJohnT
- Thank you received: 994
22 Jan 2021 00:04 #196163
by BigJohnT
Replied by BigJohnT on topic Installing the 7i96 Configuration Tool
First thing I see is your trying to install it in a way that is not tested. Only installing the .deb with gdebi is tested. Make sure you have the latest deb file.
jethornton.github.io/7i96/install.html
JT
JT
- Ewok2
22 Jan 2021 07:27 - 22 Jan 2021 17:45 #196181
by Ewok2
Replied by Ewok2 on topic Installing the 7i96 Configuration Tool
Oups sorry I see a .deb and install it as other
Last edit: 22 Jan 2021 17:45 by Ewok2.
- Ewok2
22 Jan 2021 17:44 #196250
by Ewok2
I have try to install the latest version gdebi but I get 2 error durring install...
any idea?
any idea?
- Ewok2
22 Jan 2021 18:56 #196259
by Ewok2
Hello JohnT
I am not good in python but when looking at the "c7i96.py" file line 307 it seems compare to other line that setText is waiting for a string ?
Does the letter "f" behind the '{fpm} IPM' normal?
And same question tor the file "card-broken.py", line 10 ?
the letter "f" at the beginning of the command ?
- BigJohnT
22 Jan 2021 23:57 #196297
by BigJohnT
This is line 307 in c7i96.py
line 317 in c7i96.py is
A formatted string starts with the letter f or F then a single or double quote and inside the curly brackets is any code that should be evaluated.
The card-broken.py file is not even used and not even there any more. Perhaps you need a fresh copy of the deb and using the instructions install it with gdebi.
Quite possible that you are tying to use python 2 and install with setup.py which will not work at all.
JT
if text:line 317 in c7i96.py is
self.maxVelocityLbl.setText(f'{fpm} IPM')A formatted string starts with the letter f or F then a single or double quote and inside the curly brackets is any code that should be evaluated.
JT
- Ewok2
23 Jan 2021 14:54 #196336
by Ewok2
Oups I was wrong for the syntax of python
need to learn more about python...
I have used the gdebi tools and the answer to python -V is 3.5.3
I have try with 1.1-1 deb package and get
and with the latest 1.2.3-1 and get :
don't no wy it does not work for me???
Selecting previously unselected package python3-c7i96.
(Reading database ... 164468 files and directories currently installed.)
Preparing to unpack .../python3-c7i96_1.1-1_all.deb ...
Unpacking python3-c7i96 (1.1-1) ...
Setting up python3-c7i96 (1.1-1) ...
File "/usr/lib/python3/dist-packages/c7i96/c7i96.py", line 238
dpkg: error processing package python3-c7i96 (--install):
subprocess installed post-installation script returned error exit status 1
Processing triggers for gnome-menus (3.13.3-9) ...
Processing triggers for desktop-file-utils (0.23-1) ...
Processing triggers for mime-support (3.60) ...and with the latest 1.2.3-1 and get :
Preparing to unpack .../python3-c7i96_1.2.3-1_all.deb ...
Unpacking python3-c7i96 (1.2.3-1) ...
Setting up python3-c7i96 (1.2.3-1) ...
File "/usr/lib/python3/dist-packages/c7i96/c7i96.py", line 279
File "/usr/lib/python3/dist-packages/c7i96/card.py", line 47
parent.errorMsgOk(f'LinuxCNC must be running\nthe {parent.configName.text()} configuration', 'Error')
File "/usr/lib/python3/dist-packages/c7i96/extcmd.py", line 72
self.message(f"Executing process {self.p1.program()}")
Processing triggers for mime-support (3.60) ...don't no wy it does not work for me???
- BigJohnT
23 Jan 2021 21:48 - 23 Jan 2021 21:51 #196364
by BigJohnT
Your python version is too old... you need a minimum of Python 3.6 for f strings to work. This was introduced 6 years ago in 2015.
www.python.org/dev/peps/pep-0498/
What OS are you trying to install it on?
JT
JT
Last edit: 23 Jan 2021 21:51 by BigJohnT.
- Ewok2
24 Jan 2021 12:52 #196404
by Ewok2
Ok so the problem is found, thanks
I was in a Stretch distribution... (witch works with your tools 2 years ago
I will update to buster!
Many thanks
Many thanks
- Ewok2
24 Jan 2021 15:08 #196413
by Ewok2
Upgrade to Debian 10 with python 3.7.3 and it's works!!!
now I have to configure the spindle
Time to create page: 0.228 seconds
