Installing the 7i96 Configuration Tool
- BigJohnT
- Thank you received: 994
24 Jan 2021 18:53 #196448
by BigJohnT
Replied by BigJohnT on topic Installing the 7i96 Configuration Tool
Make sure you get the latest deb for the 7i96 Configuration Tool, I just fixed a few things and upgraded some things.
JT
JT
- Ewok2
24 Jan 2021 19:04 #196452
by Ewok2
Replied by Ewok2 on topic Installing the 7i96 Configuration Tool
I have installed the 1.2.3-1 ...
I will test the upgrade procedure
- BigJohnT
24 Jan 2021 19:31 #196458
by BigJohnT
1.2.4 is the latest version now... I've been busy programming today
JT
JT
- Boris
31 Jan 2021 13:48 #197217
by Boris
Replied by Boris on topic Installing the 7i96 Configuration Tool
Hi all - first post here having only recently got into a lathe project.
New to Linux as well as LinuxCNC so am very slowly picking up the vernacular. There seems like a mountain of it!!
I am trying to install and launch the 7i96 tool. I have Debian 10.6 and Python 3.7.4. I downloaded gdebi as per the instructions on github and seem to have it installed but I'm not sure it has installed properly. The program is in the LinuxCNC folder but is labelled "Something" and won't launch.
I tried reinstalling the OS in case I'd mixed up the installation somehow. Have read through the threads but am not really sure where I've gone wrong?
Any pointers appreciated. Cheers
- Clive S
- Thank you received: 486
31 Jan 2021 14:47 #197218
by Clive S
Replied by Clive S on topic Installing the 7i96 Configuration Tool
There may be a problem with the tool.
See this:- forum.linuxcnc.org/27-driver-boards/4113...ions?start=30#197214
If it is Then John will no doubt fix it.
- BigJohnT
31 Jan 2021 23:40 #197256
by BigJohnT
Odd, I'll see if I can determine what is up.
JT
JT
- BigJohnT
31 Jan 2021 23:51 #197257
by BigJohnT
Download the .deb again and reinstall, I might have introduced a bug but everything is working on this end now.
JT
JT
- Boris
01 Feb 2021 16:44 #197315
by Boris
Hi JT - downloaded the new deb and it works a charm. Thank you for that.
- BigJohnT
02 Feb 2021 00:19 - 02 Feb 2021 00:21 #197355
by BigJohnT
Great to hear, I just uploaded a new deb with some improvements...
JT
JT
Last edit: 02 Feb 2021 00:21 by BigJohnT.
Time to create page: 0.156 seconds
