Using 7i96 to Switch 110V Relay for Palm Router
- kotlikm
28 Jan 2021 13:33 #196937
by kotlikm
Replied by kotlikm on topic Using 7i96 to Switch 110V Relay for Palm Router
Thanks for taking a look, this is what i assume should trigger output zero when i send a code for spindle on.
# --- SPINDLE-ENABLE ---
net spindle-enable => hm2_7i96.0.ssr.00.out-00
- Thank you received: 5323
28 Jan 2021 17:05 - 28 Jan 2021 17:06 #196967
Replied by PCW on topic Using 7i96 to Switch 110V Relay for Palm Router
The signal spindle-enable is not connected to any source in your hal file
You would to add need something like:
net spindle-enable <= spindle.0.on
Last edit: 28 Jan 2021 17:06 by PCW.
- kotlikm
28 Jan 2021 17:12 #196970
by kotlikm
Would that also go under
# --- SPINDLE-ENABLE --- ?
I didn't see any other options in stepping through PNCCONF to add any additional spindle enable sources.
- kotlikm
28 Jan 2021 17:33 #196975
by kotlikm
Was able to run out to the shop. That did it, Thank you so much for the help.
28 Jan 2021 17:37 #196977
Might be a bug in pncconf when setting up really minimal spindle control
with just a on/off output
Time to create page: 1.505 seconds
