7i76e Configuration Tool Tester Needed
- BigJohnT
- Thank you received: 994
02 May 2021 20:54 #207676
by BigJohnT
7i76e Configuration Tool Tester Needed was created by BigJohnT
If anyone has a 7i76e and a bit of time I'd appreciate some testing of the tool and any feedback you might have. AFAIK it will make a basic working configuration minus the spindle... still working on that.
gnipsel.com/mesa/7i76e/index.html
JT
JT
The following user(s) said Thank You: Bari
- EragonPower
- Thank you received: 4
11 May 2021 08:04 #208527
by EragonPower
Replied by EragonPower on topic 7i76e Configuration Tool Tester Needed
I have a 7i76e and a bit of time to spare
- EragonPower
11 May 2021 08:43 - 11 May 2021 08:55 #208529
by EragonPower
I was downloading and installing the tool and i've hit a snag, the link doesen't point to nothing
EDIT: i've downloaded the .deb file directly from your github, tried to install it with gdebi, it closes and nothing happens
Last edit: 11 May 2021 08:55 by EragonPower. Reason: New discoveries
- Thank you received: 7501
11 May 2021 11:56 #208538
Replied by tommylight on topic 7i76e Configuration Tool Tester Needed
404 on the download page.
- EragonPower
11 May 2021 11:58 #208539
by EragonPower
Found it here: github.com/jethornton/7i76e
- BigJohnT
11 May 2021 14:48 - 11 May 2021 15:06 #208557
by BigJohnT
Replied by BigJohnT on topic 7i76e Configuration Tool Tester Needed
Ok, I'll fix that ASAP.
Edit: Sorry forgot to upload the install document after making the version change. This is why I need testers, thanks for testing the download link.
JT
JT
Last edit: 11 May 2021 15:06 by BigJohnT.
- BigJohnT
11 May 2021 14:49 #208558
by BigJohnT
Thanks for testing, I'll check that.
JT
JT
- BigJohnT
11 May 2021 16:16 #208563
by BigJohnT
Make sure you downloaded the latest version. The download link in the install page now works. After downloading check the md5sum to make sure there are no issues with the download.
What is "It closes"? Gdebi or the Configuration Tool?
What OS are you using?
JT
JT
- EragonPower
11 May 2021 16:55 - 11 May 2021 16:58 #208565
by EragonPower
I'm using the last revision of LinuxCNC.
As soon as a click on "Install Package" on Gdebi it closes and i don't know why
EDIT: i've managed to install the package with dpkg without any problem
Last edit: 11 May 2021 16:58 by EragonPower. Reason: tool installation completed with dpkg
- EragonPower
11 May 2021 17:18 #208567
by EragonPower
After playing around with the tool for some minutes i found out those things:
When the card is not connected clicking on "CPU" or "NIC" buttons into the info page will make the tool crash
Sometimes clicking "Calculate" and/or switching from GHz to MHz and back in the PC tab without the card connected will make the tool freeze
Time to create page: 0.765 seconds
