7i76e Configuration Tool Tester Needed
  • BigJohnT
  • BigJohnT's Avatar Topic Author
  • Administrator
  • Administrator
11 May 2021 18:05 #208569 by BigJohnT
Replied by BigJohnT on topic 7i76e Configuration Tool Tester Needed
Did Gdebi have any Lintian errors on that tab.
If you run the tool from a terminal you can capture the errors for me and thanks for testing.
7i76e
JT
11 May 2021 18:14 #208570 by EragonPower
Replied by EragonPower on topic 7i76e Configuration Tool Tester Needed
Gdebi spits out this error while trying to install the tool:
ERROR:root:lock.release failed
File "/usr/share/gdebi/GDebi/GDebiGtk.py", line 857, in finish_dpkg
lock.release()
RuntimeError: release unlocked lock
Clicking the "CPU" button it gives this error:
File "/usr/lib/python3/dist-packages/lib7i76e/pcinfo.py", line 10, in cpuInfo
parent.extcmd.job(cmd="lscpu", args=None, dest=parent.infoPTE)
AttributeError: 'MainWindow' object has no attribute 'infoPTE'
Aborted
And clicking the "NIC" button gives this error:
File "/usr/lib/python3/dist-packages/lib7i76e/pcinfo.py", line 13, in nicInfo
parent.extcmd.job(cmd="lspci", args=None, dest=parent.infoPTE)
Aborted
11 May 2021 18:17 #208571 by EragonPower
Another error is the following:
File "/usr/lib/python3/dist-packages/lib7i76e/pcinfo.py", line 32, in readTmax
parent.extcmd.job(cmd="halcmd", args=, dest=parent.tmaxPTE)
AttributeError: 'MainWindow' object has no attribute 'tmaxPTE'
Aborted
Only thing i've done is to click the "Read tMax" without the 7i76e
  • BigJohnT
  • Administrator
  • Administrator
11 May 2021 21:13 #208585 by BigJohnT
lock.release()
That looks like something has a lock on the package manager like synaptic package manager or apt.
JT
  • BigJohnT
  • Administrator
  • Administrator
11 May 2021 21:15 #208586 by BigJohnT
Thanks for the bug report, Those are easy fixes for me. And thanks again for testing. I'll fix them in the morning over my coffee and push a new deb.
JT
Moderators: PCWjmelson
Time to create page: 0.212 seconds
