5i24-16 + 7i52S + 7i44
13 Jun 2021 09:18 #211926 by highbiker
5i24-16 + 7i52S + 7i44 was created by highbiker
before I order mesa cards, I would like to ask whether my setup is ok.
I have 4 stepper-motors, 4 RS-422 Encoder and a smart serial device. So I would like to buy:
1x 5i24-16
1x 5i72s (for 4 Stepper and 4 RS-422 Encoder)
1x 5i44 (RJ45 Smart Serial Interface)
I also looked into the *.vhd files of the hostmot2 driver and found the
PIN_SVSTSS6_4_8_7I52S_72.vhd (I attached the contents of that file in my post).
From the pinout the cards should fit, but I did not find a corresponding bit file. Did I missed it or do I have to create it by hand or is my setup even not possible?
Greetings
File Name: PIN_SVST6_...13-2.txt
File Size:11 KB
13 Jun 2021 13:43 #211935 by PCW
Replied by PCW on topic 5i24-16 + 7i52S + 7i44
File Name: 5i24_16_sv...52sd.zip
File Size:118 KB
Would be the correct bit file for a 5I24-16, 1x7I52S, 1x7I44
The following user(s) said Thank You: highbiker
04 Dec 2021 22:55 #228367 by highbiker
Replied by highbiker on topic 5i24-16 + 7i52S + 7i44
I have issues with that firmware. I flashed successfully the 5i24_16_svstss6_6_8_7i52sd.bit via newest mesaflash from git:
XXX@YYY:/usr/lib/firmware/hm2/5i24$ sudo mesaflash --device 5i24 --write 5i24_16_svstss6_6_8_7i52sd.bit
[sudo] Passwort für wetzel:
Checking file... OK
  File type: BIT file
Boot sector OK
EEPROM sectors to write: 8, max sectors in area: 16
Erasing EEPROM sectors starting from 0x100000...
  |EEEEEEEE
Programming EEPROM sectors starting from 0x100000...
  |WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW
Board configuration updated successfully.
Checking file... OK
  File type: BIT file
Boot sector OK
Verifying EEPROM sectors starting from 0x100000...
  |VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
Board configuration verified successfully.
You must power cycle the hardware or use the --reload command to load a new firmware.
XXX@YYY:/usr/lib/firmware/hm2/5i24$ sudo mesaflash --device 5i24 --reload
Waiting for FPGA configuration...OK
mesaflash --device 5i24 --readhmid seems to be OK too:
XXX@YYY:/usr/lib/firmware/hm2/5i24$ sudo mesaflash --device 5i24 --readhmid
Configuration Name: HOSTMOT2
  BoardName : MESA5I24
  FPGA Size: 16 KGates
  FPGA Pins: 256
  Number of IO Ports: 3
  Width of one I/O port: 24
  Clock Low frequency: 33.3333 MHz
  Clock High frequency: 200.0000 MHz
  IDROM Type: 3
  Instance Stride 0: 4
  Instance Stride 1: 64
  Register Stride 0: 256
  Register Stride 1: 256
Modules in configuration:
  Module: WatchDog
  There are 1 of WatchDog in configuration
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  ClockFrequency: 33.333 MHz
  Register Stride: 256 bytes
  Instance Stride: 4 bytes
  Module: WatchDog
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  Module: IOPort
  There are 3 of IOPort in configuration
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: MuxedQCount
  There are 6 of MuxedQCount in configuration
  Version: 4
  Registers: 5
  BaseAddress: 3600
  Module: MuxedQCountSel
  There are 1 of MuxedQCountSel in configuration
  Version: 0
  Registers: 0
  BaseAddress: 0000
  Module: SSerial
  There are 1 of SSerial in configuration
  Version: 0
  Registers: 6
  BaseAddress: 5B00
  Instance Stride: 64 bytes
  Module: StepGen
  There are 6 of StepGen in configuration
  Version: 2
  Registers: 10
  BaseAddress: 2000
  Module: LED
  There are 1 of LED in configuration
  Version: 0
  Registers: 1
  BaseAddress: 0200
Configuration pin-out:
IO Connections for P4
Pin#                  I/O   Pri. func    Sec. func       Chan      Pin func        Pin Dir
 1                      0   IOPort       None
 3                      1   IOPort       MuxedQCount      0        MuxQ-A          (In)
 5                      2   IOPort       MuxedQCount      0        MuxQ-B          (In)
 7                      3   IOPort       MuxedQCount      0        MuxQ-IDX        (In)
 9                      4   IOPort       MuxedQCount      1        MuxQ-A          (In)
11                      5   IOPort       MuxedQCount      1        MuxQ-B          (In)
13                      6   IOPort       MuxedQCount      1        MuxQ-IDX        (In)
15                      7   IOPort       MuxedQCount      2        MuxQ-A          (In)
17                      8   IOPort       MuxedQCount      2        MuxQ-B          (In)
19                      9   IOPort       MuxedQCount      2        MuxQ-IDX        (In)
21                     10   IOPort       MuxedQCountSel   0        MuxSel0         (Out)
23                     11   IOPort       StepGen          5        Step/Table1     (Out)
25                     12   IOPort       StepGen          5        Dir/Table2      (Out)
27                     13   IOPort       StepGen          4        Step/Table1     (Out)
29                     14   IOPort       StepGen          4        Dir/Table2      (Out)
31                     15   IOPort       StepGen          3        Step/Table1     (Out)
33                     16   IOPort       StepGen          3        Dir/Table2      (Out)
35                     17   IOPort       StepGen          2        Step/Table1     (Out)
37                     18   IOPort       StepGen          2        Dir/Table2      (Out)
39                     19   IOPort       StepGen          1        Step/Table1     (Out)
41                     20   IOPort       StepGen          1        Dir/Table2      (Out)
43                     21   IOPort       StepGen          0        Step/Table1     (Out)
45                     22   IOPort       StepGen          0        Dir/Table2      (Out)
47                     23   IOPort       None
IO Connections for P3
 1                     24   IOPort       None
 3                     25   IOPort       None
 5                     26   IOPort       None
 7                     27   IOPort       None
 9                     28   IOPort       None
11                     29   IOPort       None
13                     30   IOPort       None
15                     31   IOPort       None
17                     32   IOPort       None
19                     33   IOPort       None
21                     34   IOPort       None
23                     35   IOPort       None
25                     36   IOPort       None
27                     37   IOPort       None
29                     38   IOPort       None
31                     39   IOPort       None
33                     40   IOPort       None
35                     41   IOPort       None
37                     42   IOPort       None
39                     43   IOPort       None
41                     44   IOPort       None
43                     45   IOPort       None
45                     46   IOPort       None
47                     47   IOPort       None
IO Connections for P2
 1                     48   IOPort       SSerial          0        RXData0         (In)
 3                     49   IOPort       SSerial          0        RXData1         (In)
 5                     50   IOPort       SSerial          0        RXData2         (In)
 7                     51   IOPort       SSerial          0        RXData3         (In)
 9                     52   IOPort       SSerial          0        TXData0         (Out)
11                     53   IOPort       SSerial          0        TXEn0           (Out)
13                     54   IOPort       SSerial          0        TXData1         (Out)
15                     55   IOPort       SSerial          0        TXEn1           (Out)
17                     56   IOPort       SSerial          0        TXData2         (Out)
19                     57   IOPort       SSerial          0        TXEn2           (Out)
21                     58   IOPort       SSerial          0        TXData3         (Out)
23                     59   IOPort       SSerial          0        TXEn3           (Out)
25                     60   IOPort       SSerial          0        RXData4         (In)
27                     61   IOPort       SSerial          0        RXData5         (In)
29                     62   IOPort       SSerial          0        RXData6         (In)
31                     63   IOPort       SSerial          0        RXData7         (In)
33                     64   IOPort       SSerial          0        TXData4         (Out)
35                     65   IOPort       SSerial          0        TXEn4           (Out)
37                     66   IOPort       SSerial          0        TXData5         (Out)
39                     67   IOPort       SSerial          0        TXEn5           (Out)
41                     68   IOPort       SSerial          0        TXData6         (Out)
43                     69   IOPort       SSerial          0        TXEn6           (Out)
45                     70   IOPort       SSerial          0        TXData7         (Out)
47                     71   IOPort       SSerial          0        TXEn7           (Out)
But when testing my setup in halrun I got following error:
XXX@YYY:~$ halrun
halcmd: loadrt hostmot2
Note: Using POSIX realtime
halcmd: loadrt hm2_pci config="num_encoders=3 num_stepgens=4 sserial_port_0=00000000"
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i24 at 0000:04:00.0
hm2/hm2_5i24.0: Low Level init 0.15
hm2/hm2_5i24.0: found duplicate Module Descriptor for Watchdog (inconsistent firmware), not loading driver
hm2/hm2_5i24.0: failed to parse Module Descriptor 1
hm2_5i24.0: board fails HM2 registration
RTAPI_PCI: Unmapped 65536 bytes at 0x7f05919fb000
Driver probe function failed!
hm2_pci: error registering PCI driver
hm2_pci: rtapi_app_main: Operation not permitted (-1)
<stdin>:2: waitpid failed /usr/bin/rtapi_app hm2_pci
<stdin>:2: /usr/bin/rtapi_app exited without becoming ready
<stdin>:2: insmod for hm2_pci failed, returned -1
Could you please help me to solve the problem? Unfortunately I am at my wits end.
FYI: I attached the 7i52S to P4 and the 7i44 to P2.
04 Dec 2021 23:52 - 04 Dec 2021 23:52 #228368 by PCW
That's a really strange error, considering the pin file does not seem to have any errors
(certainly no duplicated watchdog entry)
The readhmid output also reflects the error (it shows a duplicate watchdog module entry)
I just re-compiled this bit file:
File Name: 5i24_16_svstss.zip
File Size:129 KB
If this fails I will try and debug this further
Last edit: 04 Dec 2021 23:52 by PCW.
05 Dec 2021 00:38 #228371 by highbiker
Hi, thank you for the quick response!
In principle the second bit file (5i24_16_svstss.zip) is working. The duplicated watchdog error is gone and the hm2_pci is loading successfully in halrun.
But from the readhmid ouput I guess that 5i24_16_svstss.zip is for a 5i24-16 setup without 7i52S and 7i44 and with pwmgens instead of stepgens.
Warning: Spoiler!
05 Dec 2021 01:35 #228373 by PCW
Ack sorry that's the last one I did,
Third ones a charm (I hope):
File Name: 5i24_16_sv...2-04.zip
File Size:126 KB
05 Dec 2021 21:53 - 05 Dec 2021 21:54 #228407 by highbiker
As you said: Third ones a charm. The last bit file is working as intended. Thanks a lot!!
Last edit: 05 Dec 2021 21:54 by highbiker.
02 Jul 2022 16:50 #246452 by zoni
Replied by zoni on topic 5i24-16 + 7i52S + 7i44
hi have you successfully install 7i52s with 5i24 if yes can you attach you config files
03 Jul 2022 10:37 #246496 by andypugh
Replied by andypugh on topic 5i24-16 + 7i52S + 7i44
The 7i52S is (as far as I am aware) an entirely passive card. So even users of other cards with the 5u24 might be able to help.
Do you have a specific question? (I am using a 5i24 on my lathe, but with a 7i49 rather than 7i52)
The following user(s) said Thank You: Deckerjwd
06 Feb 2023 01:55 #263786 by Deckerjwd
Replied by Deckerjwd on topic 5i24-16 + 7i52S + 7i44
Im running the same setup but i have a 5i24-25 card, is the 16 bit file compatible?
Moderators: PCW, jmelson
Time to create page: 0.111 seconds
