5i24-16 + 7i52S + 7i44
06 Feb 2023 02:24 #263787 by PCW
Replied by PCW on topic 5i24-16 + 7i52S + 7i44
No, you need an image built for the -25 FPGA
06 Feb 2023 02:38 #263788 by Deckerjwd
Replied by Deckerjwd on topic 5i24-16 + 7i52S + 7i44
is the 5i24_25_sssvst_6_12_6_7i52s_7i52d.bit the right one, for a 5i24-25, 7i52d and 7i44?
06 Feb 2023 16:26 #263844 by andypugh
Replied by andypugh on topic 5i24-16 + 7i52S + 7i44
Wait for PCW to be sure, but I would think so.
sssvst means Smart Serial / Servo / Stepper
The following user(s) said Thank You: Deckerjwd
06 Feb 2023 16:37 #263846 by PCW
Here is firmware for a 5i24-25 with a 7I52S +7I44
File Name: 5i24_25_sv...52sd.zip
File Size:133 KB
07 Feb 2023 01:16 #263887 by Deckerjwd
so that firmware flashed, but i get a "hm2/hm2_5i24.0: inconsistent Module Descriptor for Smart Serial Interface, not loading driver" when i launch. here is readhmid
Configuration Name: HOSTMOT2
BoardName : MESA5I24
FPGA Size: 25 KGates
FPGA Pins: 256
Number of IO Ports: 3
Width of one I/O port: 24
Clock Low frequency: 33.3333 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 16
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 33.333 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 3 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 6 of MuxedQCount in configuration
Version: 4
Registers: 5
BaseAddress: 3600
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 16 bytes
Module: StepGen
There are 6 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P4
Pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
1 0 IOPort None
3 1 IOPort MuxedQCount 0 MuxQ-A (In)
5 2 IOPort MuxedQCount 0 MuxQ-B (In)
7 3 IOPort MuxedQCount 0 MuxQ-IDX (In)
9 4 IOPort MuxedQCount 1 MuxQ-A (In)
11 5 IOPort MuxedQCount 1 MuxQ-B (In)
13 6 IOPort MuxedQCount 1 MuxQ-IDX (In)
15 7 IOPort MuxedQCount 2 MuxQ-A (In)
17 8 IOPort MuxedQCount 2 MuxQ-B (In)
19 9 IOPort MuxedQCount 2 MuxQ-IDX (In)
21 10 IOPort MuxedQCountSel 0 MuxSel0 (Out)
23 11 IOPort StepGen 5 Step/Table1 (Out)
25 12 IOPort StepGen 5 Dir/Table2 (Out)
27 13 IOPort StepGen 4 Step/Table1 (Out)
29 14 IOPort StepGen 4 Dir/Table2 (Out)
31 15 IOPort StepGen 3 Step/Table1 (Out)
33 16 IOPort StepGen 3 Dir/Table2 (Out)
35 17 IOPort StepGen 2 Step/Table1 (Out)
37 18 IOPort StepGen 2 Dir/Table2 (Out)
39 19 IOPort StepGen 1 Step/Table1 (Out)
41 20 IOPort StepGen 1 Dir/Table2 (Out)
43 21 IOPort StepGen 0 Step/Table1 (Out)
45 22 IOPort StepGen 0 Dir/Table2 (Out)
47 23 IOPort None
IO Connections for P3
1 24 IOPort None
3 25 IOPort None
5 26 IOPort None
7 27 IOPort None
9 28 IOPort None
11 29 IOPort None
13 30 IOPort None
15 31 IOPort None
17 32 IOPort None
19 33 IOPort None
21 34 IOPort None
23 35 IOPort None
25 36 IOPort None
27 37 IOPort None
29 38 IOPort None
31 39 IOPort None
33 40 IOPort None
35 41 IOPort None
37 42 IOPort None
39 43 IOPort None
41 44 IOPort None
43 45 IOPort None
45 46 IOPort None
47 47 IOPort None
IO Connections for P2
1 48 IOPort SSerial 0 RXData0 (In)
3 49 IOPort SSerial 0 RXData1 (In)
5 50 IOPort SSerial 0 RXData2 (In)
7 51 IOPort SSerial 0 RXData3 (In)
9 52 IOPort SSerial 0 TXData0 (Out)
11 53 IOPort SSerial 0 TXEn0 (Out)
13 54 IOPort SSerial 0 TXData1 (Out)
15 55 IOPort SSerial 0 TXEn1 (Out)
17 56 IOPort SSerial 0 TXData2 (Out)
19 57 IOPort SSerial 0 TXEn2 (Out)
21 58 IOPort SSerial 0 TXData3 (Out)
23 59 IOPort SSerial 0 TXEn3 (Out)
25 60 IOPort SSerial 0 RXData4 (In)
27 61 IOPort SSerial 0 RXData5 (In)
29 62 IOPort SSerial 0 RXData6 (In)
31 63 IOPort SSerial 0 RXData7 (In)
33 64 IOPort SSerial 0 TXData4 (Out)
35 65 IOPort SSerial 0 TXEn4 (Out)
37 66 IOPort SSerial 0 TXData5 (Out)
39 67 IOPort SSerial 0 TXEn5 (Out)
41 68 IOPort SSerial 0 TXData6 (Out)
43 69 IOPort SSerial 0 TXEn6 (Out)
45 70 IOPort SSerial 0 TXData7 (Out)
47 71 IOPort SSerial 0 TXEn7 (Out)
im checking all my wiring now and reading the manuals
07 Feb 2023 01:59 #263888 by PCW
This should be better:
File Name: 5i24_25_sv...2-06.zip
File Size:133 KB
07 Feb 2023 03:19 #263890 by Deckerjwd
sweet thank you, every thing seem to be working.
Moderators: PCW, jmelson
Time to create page: 0.198 seconds
