7i80hd + 7i33 + 7i37 + 7i84
- vre
- Thank you received: 17
15 Jul 2021 18:42 #214914
by vre
Replied by vre on topic 7i80hd + 7i33 + 7i37 + 7i84
Because i can't find how to change the output voltage of 7i33
what settings must change for 0-2.5-5 V analog output ?
- Thank you received: 5326
15 Jul 2021 19:43 - 15 Jul 2021 22:10 #214922
Replied by PCW on topic 7i80hd + 7i33 + 7i37 + 7i84
You would need to set the PWM channel offset mode true
and bound the PID output to 2.5 (with a PWM scale of 10)
This assumes you are running LinuxCNC 2.8.1 or greater
Last edit: 15 Jul 2021 22:10 by PCW.
- vre
15 Jul 2021 23:51 - 15 Jul 2021 23:54 #214949
by vre
From these settings linuxcnc.org/docs/html/man/man9/pid.9.html
pid output bound is this?
pid.N.output float out
The output of the PID loop, which goes to some actuator such as a motor.
Last edit: 15 Jul 2021 23:54 by vre.
- vre
18 Jul 2021 18:20 #215244
by vre
How to bound the PID output to 2.5 what are the settings?
18 Jul 2021 20:58 #215254
Via the PID maxoutput pin
for example:
setp pid.5.maxoutput 2.5
for example:
Time to create page: 0.202 seconds
