7i97 no ethernet connection
4 years 11 months ago #227972 by Arnold
Replied by Arnold on topic 7i97 no ethernet connection
When connected to internet speed 1000mbs
When "connected" to the 7i97 through parameters in description, speed 100mbs and not communication possible "ping"
I really need a hand, I have no clue what is happenning
Sorry for the long thread
4 years 11 months ago #227985 by tommylight
The PC side is OK, set the Mesa board to 10.10.10.10.
Read the manual, there is a jumper to be moved.
4 years 11 months ago #227994 by Arnold
The jumpers where w16 down, w17 down, manual specify (FIXED 192.168.1.12 as a default).....having no luck with that
I follow tommylight recomendation, so changed to FIXED FROM EEPROM, w10 down, w17 up. Manual said shipped default EEPROM is 10.10.10.10
arnold@desktop-cnclan:~$ ping 10.10.10.10 PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data. 64 bytes from 10.10.10.10: icmp_seq=1 ttl=64 time=0.516 ms 64 bytes from 10.10.10.10: icmp_seq=2 ttl=64 time=0.271 ms 64 bytes from 10.10.10.10: icmp_seq=3 ttl=64 time=0.270 ms 64 bytes from 10.10.10.10: icmp_seq=4 ttl=64 time=0.294 ms 64 bytes from 10.10.10.10: icmp_seq=5 ttl=64 time=0.272 ms 64 bytes from 10.10.10.10: icmp_seq=6 ttl=64 time=0.264 ms 64 bytes from 10.10.10.10: icmp_seq=7 ttl=64 time=0.276 ms 64 bytes from 10.10.10.10: icmp_seq=8 ttl=64 time=0.296 ms 64 bytes from 10.10.10.10: icmp_seq=9 ttl=64 time=0.269 ms 64 bytes from 10.10.10.10: icmp_seq=10 ttl=64 time=0.273 ms 64 bytes from 10.10.10.10: icmp_seq=11 ttl=64 time=0.288 ms 64 bytes from 10.10.10.10: icmp_seq=12 ttl=64 time=0.268 ms ^C --- 10.10.10.10 ping statistics --- 12 packets transmitted, 12 received, 0% packet loss, time 195ms rtt min/avg/max/mdev = 0.264/0.296/0.516/0.068 ms arnold@desktop-cnclan:~$
image missing /media/kunena/emoticons/smile.png
But now:
arnold@desktop-cnclan:~$ sudo mesaflash --device 7i97 --readhmid [sudo] password for arnold: No 7I97 board found arnold@desktop-cnclan:~$
What happens?
4 years 11 months ago #227999 by Arnold
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl: Print file information: RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/lib/linuxcnc/modules LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/lib/tcltk/linuxcnc/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.6 LINUXCNC - 2.8.2-11-g6a3d0a434 Machine configuration directory is '/home/arnold/linuxcnc/configs/basic7i97_2021-11-26' Machine configuration file is 'basic7i97.ini' INIFILE=/home/arnold/linuxcnc/configs/basic7i97_2021-11-26/basic7i97.ini VERSION=1.1 PARAMETER_FILE=linuxcnc.var TASK=milltask HALUI=halui DISPLAY=axis COORDINATES=XYZ KINEMATICS=trivkins coordinates=XYZ Starting LinuxCNC... Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io emc/iotask/ioControl.cc 702: can't load tool table. Starting HAL User Interface program: halui Found file(REL): ./basic7i97.hal Shutting down and cleaning up LinuxCNC... hm2: loading Mesa HostMot2 driver version 0.15 hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2 hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:17:00:43 hm2_eth: discovered 7I97 hm2/hm2_7i97.0: Low Level init 0.15 hm2/hm2_7i97.0: Smart Serial Firmware Version 43 hm2/hm2_7i97.0: 51 I/O Pins used: hm2/hm2_7i97.0:     IO Pin 000 (TB3-04): PWMGen #0, pin Out0 (PWM or Up) (Output) hm2/hm2_7i97.0:     IO Pin 001 (TB3-08): PWMGen #1, pin Out0 (PWM or Up) (Output) hm2/hm2_7i97.0:     IO Pin 002 (TB3-12): PWMGen #2, pin Out0 (PWM or Up) (Output) hm2/hm2_7i97.0:     IO Pin 003 (TB3-16): PWMGen #3, pin Out0 (PWM or Up) (Output) hm2/hm2_7i97.0:     IO Pin 004 (TB3-20): PWMGen #4, pin Out0 (PWM or Up) (Output) hm2/hm2_7i97.0:     IO Pin 005 (AN_ENA4): PWMGen #4, pin Not-Enable (Output) hm2/hm2_7i97.0:     IO Pin 006 (TB3-24): PWMGen #5, pin Out0 (PWM or Up) (Output) hm2/hm2_7i97.0:     IO Pin 007 (AN_ENA5): PWMGen #5, pin Not-Enable (Output) hm2/hm2_7i97.0:     IO Pin 008 (AN-ENA0..3): PWMGen #0, pin Not-Enable (Output) hm2/hm2_7i97.0:     IO Pin 009 (TB1-01/TB1-09): Muxed Encoder #0, pin Muxed A (Input) hm2/hm2_7i97.0:     IO Pin 010 (TB1-04/TB1-12): Muxed Encoder #0, pin Muxed B (Input) hm2/hm2_7i97.0:     IO Pin 011 (TB1-07/TB1-15): Muxed Encoder #0, pin Muxed Index (Input) hm2/hm2_7i97.0:     IO Pin 012 (TB1-17/TB2-01): Muxed Encoder #1, pin Muxed A (Input) hm2/hm2_7i97.0:     IO Pin 013 (TB1-20/TB2-04): Muxed Encoder #1, pin Muxed B (Input) hm2/hm2_7i97.0:     IO Pin 014 (TB1-23/TB2-07): Muxed Encoder #1, pin Muxed Index (Input) hm2/hm2_7i97.0:     IO Pin 015 (TB2-09/TB2-17): Muxed Encoder #2, pin Muxed A (Input) hm2/hm2_7i97.0:     IO Pin 016 (TB2-12/TB2-20): Muxed Encoder #2, pin Muxed B (Input) hm2/hm2_7i97.0:     IO Pin 017 (TB2-15/TB2-23): Muxed Encoder #2, pin Muxed Index (Input) hm2/hm2_7i97.0:     IO Pin 018 (Internal EncMux): Muxed Encoder Select #0, pin Mux Select 0 (Output) hm2/hm2_7i97.0:     IO Pin 019 (TB5-13/TB5-14): SSR #0, pin Out-00 (Output) hm2/hm2_7i97.0:     IO Pin 020 (TB5-15/TB5-16): SSR #0, pin Out-01 (Output) hm2/hm2_7i97.0:     IO Pin 021 (TB5-17/TB5-18): SSR #0, pin Out-02 (Output) hm2/hm2_7i97.0:     IO Pin 022 (TB5-19/TB5-20): SSR #0, pin Out-03 (Output) hm2/hm2_7i97.0:     IO Pin 023 (TB5-21/TB5-22): SSR #0, pin Out-04 (Output) hm2/hm2_7i97.0:     IO Pin 024 (TB5-23/TB5-24): SSR #0, pin Out-05 (Output) hm2/hm2_7i97.0:     IO Pin 025 (Internal InMux0): SSR #0, pin AC Ref (internal) (Output) hm2/hm2_7i97.0:     IO Pin 026 (Internal InMux1): InMux Input Mux #0, pin addr0 (Output) hm2/hm2_7i97.0:     IO Pin 027 (Internal InMux2): InMux Input Mux #0, pin addr1 (Output) hm2/hm2_7i97.0:     IO Pin 028 (Internal InMux3): InMux Input Mux #0, pin addr2 (Output) hm2/hm2_7i97.0:     IO Pin 029 (Internal InMuxData): InMux Input Mux #0, pin addr3 (Output) hm2/hm2_7i97.0:     IO Pin 030 (TB4-15/TB4-16): InMux Input Mux #0, pin muxdata (Input) hm2/hm2_7i97.0:     IO Pin 031 (TB4-17/TB4-18): IOPort hm2/hm2_7i97.0:     IO Pin 032 (TB4-17/TB4-18): IOPort hm2/hm2_7i97.0:     IO Pin 033 (P1-01): IOPort hm2/hm2_7i97.0:     IO Pin 034 (P1-02): IOPort hm2/hm2_7i97.0:     IO Pin 035 (P1-03): IOPort hm2/hm2_7i97.0:     IO Pin 036 (P1-04): IOPort hm2/hm2_7i97.0:     IO Pin 037 (P1-05): IOPort hm2/hm2_7i97.0:     IO Pin 038 (P1-06): IOPort hm2/hm2_7i97.0:     IO Pin 039 (P1-07): IOPort hm2/hm2_7i97.0:     IO Pin 040 (P1-08): IOPort hm2/hm2_7i97.0:     IO Pin 041 (P1-09): IOPort hm2/hm2_7i97.0:     IO Pin 042 (P1-11): IOPort hm2/hm2_7i97.0:     IO Pin 043 (P1-13): IOPort hm2/hm2_7i97.0:     IO Pin 044 (P1-15): IOPort hm2/hm2_7i97.0:     IO Pin 045 (P1-17): IOPort hm2/hm2_7i97.0:     IO Pin 046 (P1-19): IOPort hm2/hm2_7i97.0:     IO Pin 047 (P1-21): IOPort hm2/hm2_7i97.0:     IO Pin 048 (P1-23): IOPort hm2/hm2_7i97.0:     IO Pin 049 (P1-25): IOPort hm2/hm2_7i97.0: registered hm2_eth: in hm2_eth_reset hm2_eth: HostMot2 ethernet driver unloaded hm2: unloading Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments Debug file information: cannot gain I/O privileges - forgot 'sudo make setuid'? Note: Using POSIX non-realtime ./basic7i97.hal:225: Unknown command '3600' 3549 Stopping realtime threads Unloading hal components cannot gain I/O privileges - forgot 'sudo make setuid'? Note: Using POSIX non-realtime ----------------------------------------------------------------------- Info report created by linuxcnc_info: The file:    /tmp/linuxcnc_info.txt
4 years 11 months ago #228000 by Arnold
4 years 11 months ago #228007 by tommylight
Attach the files here, not on a third party website.
Now you have everything set up properly, except you are using a generic kernel that does not work for machine control.
And it looks like you have Intel ethernet, but we'll get back to it later.
First, what does
uname -a
say?
The following user(s) said Thank You: Arnold
Moderators: PCW, jmelson
Time to create page: 0.445 seconds
