7i97 no ethernet connection
4 years 11 months ago #227859 by tommylight
The following user(s) said Thank You: Arnold
4 years 11 months ago #227860 by Arnold
Replied by Arnold on topic 7i97 no ethernet connection
I may have follow wrong your mentioned guide, I will do it again tomorrow
I've just installed a old version www.linuxcnc.org/testing-stretch-rtpreem...-uspace-i386-r13.iso
It worked like charm doing a ping with the 7i97 !!!!!
arnoldo@debian:~$ ping 192.168.1.121
PING 192.168.1.121 (192.168.1.121): 56 data bytes
64 bytes from 192.168.1.121: icmp_seq=0 ttl=64 time=0.200 ms
64 bytes from 192.168.1.121: icmp_seq=1 ttl=64 time=0.226 ms
64 bytes from 192.168.1.121: icmp_seq=2 ttl=64 time=0.231 ms
64 bytes from 192.168.1.121: icmp_seq=3 ttl=64 time=0.227 ms
64 bytes from 192.168.1.121: icmp_seq=4 ttl=64 time=0.264 ms
64 bytes from 192.168.1.121: icmp_seq=5 ttl=64 time=0.226 ms
64 bytes from 192.168.1.121: icmp_seq=6 ttl=64 time=0.227 ms
64 bytes from 192.168.1.121: icmp_seq=7 ttl=64 time=0.225 ms
64 bytes from 192.168.1.121: icmp_seq=8 ttl=64 time=0.226 ms
64 bytes from 192.168.1.121: icmp_seq=9 ttl=64 time=0.230 ms
64 bytes from 192.168.1.121: icmp_seq=10 ttl=64 time=0.229 ms
64 bytes from 192.168.1.121: icmp_seq=11 ttl=64 time=0.234 ms
64 bytes from 192.168.1.121: icmp_seq=12 ttl=64 time=0.227 ms
64 bytes from 192.168.1.121: icmp_seq=13 ttl=64 time=0.226 ms
^C--- 192.168.1.121 ping statistics ---
14 packets transmitted, 14 packets received, 0% packet loss
round-trip min/avg/max/stddev = 0.200/0.228/0.264/0.000 ms
arnoldo@debian:~$
This old version let me use the graphical edit tool for configuration of the connection. The new version was just impossible.
Many thanks for the help!
4 years 11 months ago #227967 by Arnold
Today I made again a new fresh installation in two computer, practically same results.
LinuxCNC 2.8.2 Debian 10 Buster PREEMPT-RT ISO.
I carefully followed the instruction "Mesa ethernet setup for 7i92, 7i96, 7i76E and other ethernet Mesa boards" in:  forum.linuxcnc.org/27-driver-boards/3559...ethernet-mesa-boards
1º Install network manager
arnold@desktop-cnclan:~$ sudo apt-get install network-manager network-manager-gnome We trust you have received the usual lecture from the local System Administrator. It usually boils down to these three things:     #1) Respect the privacy of others.     #2) Think before you type.     #3) With great power comes great responsibility. [sudo] password for arnold:  Reading package lists... Done Building dependency tree        Reading state information... Done network-manager is already the newest version (1.14.6-2+deb10u1). network-manager set to manually installed. The following additional packages will be installed:   gcr gnome-keyring gnome-keyring-pkcs11 libayatana-appindicator3-1   libayatana-ido3-0.4-0 libayatana-indicator3-7 libdbusmenu-glib4   libdbusmenu-gtk3-4 libgcr-ui-3-1 libnma0 libpam-gnome-keyring   mobile-broadband-provider-info p11-kit p11-kit-modules pinentry-gnome3 Suggested packages:   network-manager-openconnect-gnome network-manager-openvpn-gnome   network-manager-vpnc-gnome network-manager-pptp-gnome pinentry-doc The following NEW packages will be installed:   gcr gnome-keyring gnome-keyring-pkcs11 libayatana-appindicator3-1   libayatana-ido3-0.4-0 libayatana-indicator3-7 libdbusmenu-glib4   libdbusmenu-gtk3-4 libgcr-ui-3-1 libnma0 libpam-gnome-keyring   mobile-broadband-provider-info network-manager-gnome p11-kit p11-kit-modules   pinentry-gnome3 0 upgraded, 16 newly installed, 0 to remove and 55 not upgraded. Need to get 4,161 kB of archives. After this operation, 17.8 MB of additional disk space will be used. Do you want to continue? [Y/n] Y Get:1 http://deb.debian.org/debian buster/main amd64 libgcr-ui-3-1 amd64 3.28.1-1 [158 kB] Get:2 http://deb.debian.org/debian buster/main amd64 gcr amd64 3.28.1-1 [245 kB] Get:3 http://deb.debian.org/debian buster/main amd64 p11-kit-modules amd64 0.23.15-2+deb10u1 [222 kB] Get:4 http://deb.debian.org/debian buster/main amd64 p11-kit amd64 0.23.15-2+deb10u1 [268 kB] Get:5 http://deb.debian.org/debian buster/main amd64 pinentry-gnome3 amd64 1.1.0-2 [66.9 kB] Get:6 http://deb.debian.org/debian buster/main amd64 gnome-keyring amd64 3.28.2-5 [1,013 kB] Get:7 http://deb.debian.org/debian buster/main amd64 gnome-keyring-pkcs11 amd64 3.28.2-5 [310 kB] Get:8 http://deb.debian.org/debian buster/main amd64 libayatana-ido3-0.4-0 amd64 0.4.4-1 [70.3 kB] Get:9 http://deb.debian.org/debian buster/main amd64 libayatana-indicator3-7 amd64 0.6.2-3 [89.5 kB] Get:10 http://deb.debian.org/debian buster/main amd64 libdbusmenu-glib4 amd64 18.10.20180917~bzr490+repack1-1 [58.0 kB] Get:11 http://deb.debian.org/debian buster/main amd64 libdbusmenu-gtk3-4 amd64 18.10.20180917~bzr490+repack1-1 [45.6 kB] Get:12 http://deb.debian.org/debian buster/main amd64 libayatana-appindicator3-1 amd64 0.5.3-4 [84.6 kB] Get:13 http://deb.debian.org/debian buster/main amd64 libnma0 amd64 1.8.20-1.1 [139 kB] Get:14 http://deb.debian.org/debian buster/main amd64 libpam-gnome-keyring amd64 3.28.2-5 [306 kB] Get:15 http://deb.debian.org/debian buster/main amd64 mobile-broadband-provider-info all 20170903-1 [54.7 kB] Get:16 http://deb.debian.org/debian buster/main amd64 network-manager-gnome amd64 1.8.20-1.1 [1,030 kB] Fetched 4,161 kB in 1s (5,765 kB/s)                Selecting previously unselected package libgcr-ui-3-1:amd64. (Reading database ... 85483 files and directories currently installed.) Preparing to unpack .../00-libgcr-ui-3-1_3.28.1-1_amd64.deb ... Unpacking libgcr-ui-3-1:amd64 (3.28.1-1) ... Selecting previously unselected package gcr. Preparing to unpack .../01-gcr_3.28.1-1_amd64.deb ... Unpacking gcr (3.28.1-1) ... Selecting previously unselected package p11-kit-modules:amd64. Preparing to unpack .../02-p11-kit-modules_0.23.15-2+deb10u1_amd64.deb ... Unpacking p11-kit-modules:amd64 (0.23.15-2+deb10u1) ... Selecting previously unselected package p11-kit. Preparing to unpack .../03-p11-kit_0.23.15-2+deb10u1_amd64.deb ... Unpacking p11-kit (0.23.15-2+deb10u1) ... Selecting previously unselected package pinentry-gnome3. Preparing to unpack .../04-pinentry-gnome3_1.1.0-2_amd64.deb ... Unpacking
2º remove wicd
arnold@desktop-cnclan:~$ sudo apt-get remove wicd wicd-gtk [sudo] password for arnold:  Reading package lists... Done Building dependency tree        Reading state information... Done Package 'wicd' is not installed, so not removed Package 'wicd-gtk' is not installed, so not removed 0 upgraded, 0 newly installed, 0 to remove and 55 not upgraded. arnold@desktop-cnclan:~$
Not removed because is not installed
3º
address 10.10.10.11
netmask 8
gateway 10.10.10.1
additional DNS 10.10.10.1
4 years 11 months ago - 4 years 11 months ago #227969 by Arnold
image missing https://i.imgur.com/OuIOzju.jpg
arnold@desktop-cnclan:~$ ping 192.168.1.121 PING 192.168.1.121 (192.168.1.121) 56(84) bytes of data. From 10.10.10.11 icmp_seq=1 Destination Host Unreachable From 10.10.10.11 icmp_seq=2 Destination Host Unreachable From 10.10.10.11 icmp_seq=3 Destination Host Unreachable From 10.10.10.11 icmp_seq=5 Destination Host Unreachable From 10.10.10.11 icmp_seq=6 Destination Host Unreachable From 10.10.10.11 icmp_seq=7 Destination Host Unreachable From 10.10.10.11 icmp_seq=11 Destination Host Unreachable From 10.10.10.11 icmp_seq=12 Destination Host Unreachable ^C --- 192.168.1.121 ping statistics --- 15 packets transmitted, 0 received, +8 errors, 100% packet loss, time 353ms pipe 4 arnold@desktop-cnclan:~$
No connection to Mesa Card 7i97
Last edit: 4 years 11 months ago by Arnold.
4 years 11 months ago #227970 by Arnold
4? See if ethtool is installed
arnold@desktop-cnclan:~$ sudo ethtool --version [sudo] password for arnold:  sudo: ethtool: command not found arnold@desktop-cnclan:~$
not installed, so I did, but first update
arnold@desktop-cnclan:~$ sudo apt-get update [sudo] password for arnold:  Hit:1 http://security.debian.org/debian-security buster/updates InRelease Hit:2 http://deb.debian.org/debian buster InRelease       Hit:3 http://deb.debian.org/debian buster-updates InRelease Hit:4 http://www.linuxcnc.org buster InRelease      Reading package lists... Done arnold@desktop-cnclan:~$ sudo apt-get install ethtool Reading package lists... Done Building dependency tree        Reading state information... Done The following NEW packages will be installed:   ethtool 0 upgraded, 1 newly installed, 0 to remove and 55 not upgraded. Need to get 121 kB of archives. After this operation, 402 kB of additional disk space will be used. Get:1 http://deb.debian.org/debian buster/main amd64 ethtool amd64 1:4.19-1 [121 kB] Fetched 121 kB in 0s (403 kB/s)    Selecting previously unselected package ethtool. (Reading database ... 86074 files and directories currently installed.) Preparing to unpack .../ethtool_1%3a4.19-1_amd64.deb ... Unpacking ethtool (1:4.19-1) ... Setting up ethtool (1:4.19-1) ... Processing triggers for man-db (2.8.5-2) ... arnold@desktop-cnclan:~$
So I installed athtool....
To see if it is ok=
arnold@desktop-cnclan:~$ sudo ethtool --version [sudo] password for arnold:  ethtool version 4.19 arnold@desktop-cnclan:~$
PCW recommendation-->Used it on eno1 (my interface)
arnold@desktop-cnclan:~$ sudo ethtool -C eno1 rx-usecs 0 [sudo] password for arnold:  arnold@desktop-cnclan:~$
arnold@desktop-cnclan:~$ ping 192.168.1.121 PING 192.168.1.121 (192.168.1.121) 56(84) bytes of data. From 10.10.10.11 icmp_seq=1 Destination Host Unreachable From 10.10.10.11 icmp_seq=2 Destination Host Unreachable From 10.10.10.11 icmp_seq=3 Destination Host Unreachable From 10.10.10.11 icmp_seq=4 Destination Host Unreachable From 10.10.10.11 icmp_seq=5 Destination Host Unreachable From 10.10.10.11 icmp_seq=6 Destination Host Unreachable From 10.10.10.11 icmp_seq=8 Destination Host Unreachable From 10.10.10.11 icmp_seq=9 Destination Host Unreachable From 10.10.10.11 icmp_seq=11 Destination Host Unreachable From 10.10.10.11 icmp_seq=14 Destination Host Unreachable From 10.10.10.11 icmp_seq=15 Destination Host Unreachable ^C --- 192.168.1.121 ping statistics --- 16 packets transmitted, 0 received, +11 errors, 100% packet loss, time 351ms pipe 4 arnold@desktop-cnclan:~$
Not working image missing /media/kunena/emoticons/sad.png
4 years 11 months ago - 4 years 11 months ago #227971 by Arnold
A bit more of my personal history:
Here the computer is connected to internet, working properly!
arnold@desktop-cnclan:~$ ethtool eno1 bash: ethtool: command not found arnold@desktop-cnclan:~$ sudo ethtool eno1 [sudo] password for arnold:  Settings for eno1:  Supported ports: [ TP ]  Supported link modes:   10baseT/Half 10baseT/Full                           100baseT/Half 100baseT/Full                           1000baseT/Full   Supported pause frame use: No  Supports auto-negotiation: Yes  Supported FEC modes: Not reported  Advertised link modes:  10baseT/Half 10baseT/Full                           100baseT/Half 100baseT/Full                           1000baseT/Full   Advertised pause frame use: No  Advertised auto-negotiation: Yes  Advertised FEC modes: Not reported  Speed: 1000Mb/s  Duplex: Full  Port: Twisted Pair  PHYAD: 1  Transceiver: internal  Auto-negotiation: on  MDI-X: on (auto)  Supports Wake-on: pumbg  Wake-on: g  Current message level: 0x00000007 (7)           drv probe link  Link detected: yes arnold@desktop-cnclan:~$ But Here I changed the connection to the configured for mesa 7i97 [code][code]arnold@desktop-cnclan:~$ sudo ethtool eno1 [sudo] password for arnold:  Settings for eno1:  Supported ports: [ TP ]  Supported link modes:   10baseT/Half 10baseT/Full                           100baseT/Half 100baseT/Full                           1000baseT/Full   Supported pause frame use: No  Supports auto-negotiation: Yes  Supported FEC modes: Not reported  Advertised link modes:  10baseT/Half 10baseT/Full                           100baseT/Half 100baseT/Full                           1000baseT/Full   Advertised pause frame use: No  Advertised auto-negotiation: Yes  Advertised FEC modes: Not reported  Speed: 100Mb/s  Duplex: Full  Port: Twisted Pair  PHYAD: 1  Transceiver: internal  Auto-negotiation: on  MDI-X: on (auto)  Supports Wake-on: pumbg  Wake-on: g  Current message level: 0x00000007 (7)           drv probe link  Link detected: yes arnold@desktop-cnclan:~$
[/code][/code]
Moderators: PCW, jmelson
Time to create page: 0.348 seconds
