- Thank you received: 45
ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
- romanetz
4 years 9 months ago #231222
by romanetz
Replied by romanetz on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
.v is a generated Verilog source file
I don't know whether J-Link supports flashing of FPGAs or not, particularly Lattice. The compiled firmware has .bin extension
- tuzki
4 years 9 months ago - 4 years 9 months ago #232440
by tuzki
Replied by tuzki on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
我在网上买的5a-75b到货了。我要测试这个神奇的项目。5a-75b是否有望成为台面板的替代品
Last edit: 4 years 9 months ago by tuzki.
- romanetz
4 years 9 months ago #232599
by romanetz
I did some tests on my table CNC3018 mill and with larger mill. Everything operated as expected.
The pinout and the latest version of driver is in attachment (changed: added possibility to set idle state of step and dir signals)
I'll share the latest firmware source tonight, it's on another PC
- ALittleOffTheRails
- Visitor
4 years 9 months ago #232601
by ALittleOffTheRails
Replied by ALittleOffTheRails on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Great work. And thank you for sharing.
Any links to the board you are using ? I'd like to give this a try. Just want to be on the same field so things should be easier to debug when I mess up, rather than trying to work out whether it's an issue with the board or just me. I have a small 3 axis EleksMake cnc mill I can use as a test bed.
Any chance of being able to implement a spindle encoder (for lathe threading) ?
Not to sound pushy, ideally 1 spindle encoder and 2 mpg inputs would be great for a lateh. Although the MPGs could be realised by the linuxcnc encoder comp.
- romanetz
4 years 9 months ago #232606
by romanetz
There are encoder processing blocks already, but due to the lack of inputs (totally 24) i decided to disable them. Well, in the existing situation, it's possible to let user to tradeoff between number of encoders and digital inputs for any particular application by some firmware and driver modification.
Besides, there is another board colorlight 5a-75e which has twice as many I/Os (totally 102)
aliexpress.com/item/1005002754051460.html
It has the same FPGA (that makes porting of gateware rather easy) and in general described here:
github.com/q3k/chubby75/blob/master/5a-75e/hardware_V7.1.md
I'll order the board and give it a try
The following user(s) said Thank You: ALittleOffTheRails
- Visitor
4 years 9 months ago #232609
Many many thanks, just ordered the one you suggested. So I'll do see serious reading and play the waiting game, and with a bit of luck the Australian Gumbernment will grant the package entry to the country.
Time to create page: 0.237 seconds
