- Thank you received: 45
ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
- romanetz
2 weeks 4 days ago #350244
by romanetz
Replied by romanetz on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Update: PREOP reached, full SII EEPROM interface workingQuick update on the Colorlight 5A-75E EtherCAT slave.Since my last post, quite a bit has moved:What works now:
CoE mailbox is not implemented on the FPGA side yet, so IgH fails on
CoE SDO upload (
PDO assign) and never reaches SAFEOP/OP.Next steps:
github.com/romanetz/liteethercat Architecture and roadmap:
in the repo.The project continues the same modular LiteX approach. Once the slave
is in OP and HAL pins react to encoder movement, I'll post a video.
- SII EEPROM emulation fully implemented and verified with IgH master
reads identity correctly:Code:ethercat slaves -v
- Vendor Id:
, Product code:Code:0xDEADBABECode:0x00C0FFEE
- All SII categories parsed: STRINGS, GENERAL, FMMU, SYNCM
- Vendor Id:
- AL state machine:
Code:INIT → PREOP
- IgH configures SM0/SM1 and accepts the slave in PREOP
CoE SDO upload (
0x1C12
- Remove CoE declaration from ESI to bypass mailbox requirement for
Phase 1 (bring-up with LinuxCNC and quadrature encoders) - Then decide: implement mailbox via VexRiscv + SOES (Phase 2), or
keep CoE-free with PDO mapping from ESI
docs/architecture.md
The following user(s) said Thank You: meister, besriworld, wodrak
- romanetz
2 weeks 4 days ago #350245
by romanetz
(venv) engin@engin:~/litex-work/liteeth/bench/ESC$ ethercat slaves -v -p 0
=== Master 0, Slave 0 ===
Device: Main
State: PREOP
Flag: E
Identity:
Vendor Id: 0xdeadbabe
Product code: 0x00c0ffee
Revision number: 0x00000001
Serial number: 0x00000000
DL information:
FMMU bit operation: no
Distributed clocks: no
Port Type Link Loop Signal NextSlave
0 MII up open yes -
1 MII down closed no -
2 N/A down closed no -
3 N/A down closed no -
Mailboxes:
Bootstrap RX: 0x0000/0, TX: 0x0000/0
Standard RX: 0x1000/128, TX: 0x1080/128
Supported protocols: CoE
General:
Group: Colorlight5A75E
Image name:
Order number:
Device name: Colorlight 5A-75E EtherCAT Device
CoE details:
Enable SDO: yes
Enable SDO Info: no
Enable PDO Assign: no
Enable PDO Configuration: no
Enable Upload at startup: no
Enable SDO complete access: no
Flags:
Enable SafeOp: no
Enable notLRW: no
Current consumption: 0 mA
Device: Main
State: PREOP
Flag: E
Identity:
DL information:
0 MII up open yes -
Mailboxes:
General:
Image name:
Order number:
CoE details:
Enable SDO: yes
Enable SDO Info: no
Flags:
Enable SafeOp: no
Enable notLRW: no
The following user(s) said Thank You: besriworld, wodrak, NWE
Time to create page: 0.497 seconds
