ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
- wuyatom
3 years 9 months ago - 3 years 9 months ago #263001
by wuyatom
Replied by wuyatom on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Last edit: 3 years 9 months ago by wuyatom.
- wuyatom
3 years 9 months ago #263003
by wuyatom
loadrt [KINS]KINEMATICS
loadrt litexcnc
loadrt litexcnc_eth config_file="[LITEXCNC]CONFIG_FILE"
loadrt pos2vel number=6
# Add the functions to the thread
addf [LITEXCNC](NAME).read servo-thread
addf pos2vel.convert servo-thread
addf [LITEXCNC](NAME).write servo-thread
#STEPGEN
# - timings (prevent re-calculation)
net pos2vel.period-s <= [LITEXCNC](NAME).stepgen.period-s
net pos2vel.period-s-recip <= [LITEXCNC](NAME).stepgen.period-s-recip
#STEPGEN - X-AXIS
# POS2VEL
# - position control
net xpos-fb <= [LITEXCNC](NAME).stepgen.00.position_prediction
net xpos-fb => joint.0.motor-pos-fb
net xpos-fb => pos2vel.0.position-feedback
net xvel-fb pos2vel.0.velocity-feedback <= [LITEXCNC](NAME).stepgen.00.velocity-prediction
net xpos-cmd pos2vel.0.position-cmd <= joint.0.motor-pos-cmd
# - settings
setp pos2vel.0.max-acceleration [JOINT_0]STEPGEN_MAXACCEL
# setp pos2vel.0.debug 1
# STEPGEN
# - Setup of timings
setp [LITEXCNC](NAME).stepgen.00.position-scale [JOINT_0]SCALE
setp [LITEXCNC](NAME).stepgen.00.steplen 5000
setp [LITEXCNC](NAME).stepgen.00.stepspace 5000
setp [LITEXCNC](NAME).stepgen.00.dir-hold-time 10000
setp [LITEXCNC](NAME).stepgen.00.dir-setup-time 10000
setp [LITEXCNC](NAME).stepgen.00.max-velocity [JOINT_0]MAX_VELOCITY
setp [LITEXCNC](NAME).stepgen.00.max-acceleration [JOINT_0]STEPGEN_MAXACCEL
# setp [LITEXCNC](NAME).stepgen.00.debug 1
# - Connect velocity command
net xvel_cmd pos2vel.0.velocity-cmd => [LITEXCNC](NAME).stepgen.00.velocity-cmd
# - Set the acceleration to be used (NOTE: pos2vel has fixed acceleration)
setp [LITEXCNC](NAME).stepgen.00.acceleration-cmd [JOINT_0]STEPGEN_MAXACCEL
# - enable the drive
net xenable joint.0.amp-enable-out => [LITEXCNC](NAME).stepgen.00.enable
#STEPGEN - Y-AXIS
# POS2VEL
net ypos-fb <= [LITEXCNC](NAME).stepgen.01.position_prediction
net ypos-fb => joint.1.motor-pos-fb
net ypos-fb => pos2vel.1.position-feedback
net yvel-fb pos2vel.1.velocity-feedback <= [LITEXCNC](NAME).stepgen.01.velocity-prediction
net ypos-cmd pos2vel.1.position-cmd <= joint.1.motor-pos-cmd
# - settings
setp pos2vel.1.max-acceleration [JOINT_1]STEPGEN_MAXACCEL
# STEPGEN
setp [LITEXCNC](NAME).stepgen.01.position-scale [JOINT_1]SCALE
setp [LITEXCNC](NAME).stepgen.01.steplen 5000
setp [LITEXCNC](NAME).stepgen.01.stepspace 5000
setp [LITEXCNC](NAME).stepgen.01.dir-hold-time 10000
setp [LITEXCNC](NAME).stepgen.01.dir-setup-time 10000
setp [LITEXCNC](NAME).stepgen.01.max-velocity [JOINT_1]MAX_VELOCITY
setp [LITEXCNC](NAME).stepgen.01.max-acceleration [JOINT_1]STEPGEN_MAXACCEL
net yvel_cmd pos2vel.1.velocity-cmd => [LITEXCNC](NAME).stepgen.01.velocity-cmd
setp [LITEXCNC](NAME).stepgen.01.acceleration-cmd [JOINT_1]STEPGEN_MAXACCEL
net yenable joint.1.amp-enable-out => [LITEXCNC](NAME).stepgen.01.enable
#STEPGEN - Z-AXIS
# POS2VEL
net zpos-fb <= [LITEXCNC](NAME).stepgen.02.position_prediction
net zpos-fb => joint.2.motor-pos-fb
net zpos-fb => pos2vel.2.position-feedback
net zvel-fb pos2vel.2.velocity-feedback <= [LITEXCNC](NAME).stepgen.02.velocity-prediction
net zpos-cmd pos2vel.2.position-cmd <= joint.2.motor-pos-cmd
# - settings
setp pos2vel.2.max-acceleration [JOINT_2]STEPGEN_MAXACCEL
# STEPGEN
setp [LITEXCNC](NAME).stepgen.02.position-scale [JOINT_2]SCALE
setp [LITEXCNC](NAME).stepgen.02.steplen 5000
setp [LITEXCNC](NAME).stepgen.02.stepspace 5000
setp [LITEXCNC](NAME).stepgen.02.dir-hold-time 10000
setp [LITEXCNC](NAME).stepgen.02.dir-setup-time 10000
setp [LITEXCNC](NAME).stepgen.02.max-velocity [JOINT_2]MAX_VELOCITY
setp [LITEXCNC](NAME).stepgen.02.max-acceleration [JOINT_2]STEPGEN_MAXACCEL
net zvel_cmd pos2vel.2.velocity-cmd => [LITEXCNC](NAME).stepgen.02.velocity-cmd
setp [LITEXCNC](NAME).stepgen.02.acceleration-cmd [JOINT_2]STEPGEN_MAXACCEL
net zenable joint.2.amp-enable-out => [LITEXCNC](NAME).stepgen.02.enable
#net estop-out => [LITEXCNC](NAME).gpio.j1:8.out
# toolchange setup
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed => hal_manualtoolchange.changed
loadrt litexcnc
#STEPGEN
#STEPGEN - X-AXIS
# POS2VEL
# - settings
# STEPGEN
#STEPGEN - Y-AXIS
# POS2VEL
# - settings
# STEPGEN
#STEPGEN - Z-AXIS
# POS2VEL
# - settings
# STEPGEN
# toolchange setup
- deroj
- Thank you received: 21
3 years 9 months ago #263016
by deroj
Replied by deroj on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
To find out you can open terminal and run "halrun".
then load the two modules with
loadrt litexcnc
loadrt litexcnc_eth config_file="/path/to/config.json"
after successfully loaded type
show pin
which gives you a list of all pins and their names
loadrt litexcnc
show pin
- TOLP2
- Thank you received: 178
3 years 9 months ago #263029
by TOLP2
Replied by TOLP2 on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
@wuyatom: please clarify what you mean with 'cannot press E-Stop'. Is this in the GUI, or is it a physical button?
In case of the GUI: I cannot help you as you are using Axis and I use GMOCCAPY.
If it is a physical button. In the HAL file you posted I don't see any input defined for the E-stop. If you have an input assigned to the E-Stop and it is still not running, please verify you've modified the buffers. The default buffers are output only!
- wuyatom
3 years 9 months ago #263059
by wuyatom
- wuyatom
3 years 9 months ago #263060
by wuyatom
The above gui shows that external estop is enabled, and I have minimized hal
Time to create page: 8.402 seconds
