Anilam with 7i97
- Kylizer
03 Feb 2022 09:32 #233884
by Kylizer
Anilam with 7i97 was created by Kylizer
I'm not sure how different the 3000M is from the 1100M but I basically tossed out everything but the drives and power supply and use a 5i25 and 7i77 (7i92's were not available then). IIRC the drives had to have the enable pin grounded to enable them, so I use a relay for that.
This was from BigJohnT in another forum post and I was wondering if someone could go a little more in depth about "IIRC the drives had to have the enable pin grounded to enable them, so I use a relay for that."
I am at this specific point on my setup which is an Anilam 3000M but with a Mesa 7i97 board.
- BigJohnT
- Thank you received: 994
03 Feb 2022 11:32 #233893
by BigJohnT
Replied by BigJohnT on topic Anilam with 7i97
There's a pin on each drive on the 1100M that if not grounded the drives won't power up. Just depends on what drives you have.
JT
JT
- Kylizer
03 Feb 2022 16:50 #233922
by Kylizer
Replied by Kylizer on topic Anilam with 7i97
- Kylizer
03 Feb 2022 16:51 #233923
by Kylizer
Do you know what the pin was on yours that you had to enable?
- BigJohnT
03 Feb 2022 18:03 #233928
by BigJohnT
My guess is pin 9 on J1, do you have a photo of your drive?
I'll have to look tomorrow, snowed in and cooking some gumbo...
JT
JT
- Kylizer
04 Feb 2022 07:19 #233968
by Kylizer
By drive do you mean my amplifier?
- Kylizer
04 Feb 2022 11:23 - 04 Feb 2022 11:25 #233982
by Kylizer
Last edit: 04 Feb 2022 11:25 by Kylizer.
- BigJohnT
05 Feb 2022 07:04 - 05 Feb 2022 07:06 #234020
by BigJohnT
Those are different servo drives than mine. The inhibit pin sounds like it inhibits the drive not enables the drive.
1100m Servo Drive cabinet
gnipsel.com/shop/bp1/bp1-02.xhtml
JT
JT
Last edit: 05 Feb 2022 07:06 by BigJohnT.
- Kylizer
05 Feb 2022 09:16 #234027
by Kylizer
oh, well I guess I was assuming the inhibit was just another word for enable. Im guessing that inhibit is something that has to happen along with enabling maybe? Also I have my encoders set up single and because I thought that is how the amplifier had it but I read that my amp can be used for differential as well. Do you suppose that it matters much whether I run my stuff single or differential ended?
Oh I thanks for all the help man. Your one of the only people I have seen on this forum who also has done a conversion from an old Anilam system. Tough to find much on it.
- BigJohnT
06 Feb 2022 18:16 #234203
by BigJohnT
Differential is the best for electrical noise for sure.
If you disconnect the inhibit does the drive take control of the servo?
JT
JT
Time to create page: 1.828 seconds
