8i20
4 years 7 months ago #236166 by dkraft
Replied by dkraft on topic 8i20
Its the init that trips it. struggling with a way to diagnose it.
4 years 7 months ago #236172 by andypugh
Replied by andypugh on topic 8i20
Does it always trigger? Or is it OK the second time? I am wondering about transient effects as the rotor snaps in to phase.
I guess you have tried both higher and lower initvalue values?
4 years 7 months ago #236173 by dkraft
How do you drive the input enable and read the fault out physical pins on the 8i20? Do you setup pins from the driver board?
Currently testing, I'm driving input enable from 5v off the serial connector.. not sure if that is trouble.
4 years 7 months ago - 4 years 7 months ago #236201 by dkraft
Figured out the tripping error. Too low impedance on the motor detects as a short apparently.
250Kv motors will never work no matter how low you try to drive it ;)
Thanks!
Last edit: 4 years 7 months ago by dkraft.
4 years 7 months ago #236202 by andypugh
Are these RC aircraft motors?
4 years 7 months ago #236205 by PCW
Replied by PCW on topic 8i20
Yes I forgot to ask this, what type of motor and perhaps more important, what is the motor inductance?
The 8I20 is intended for medium/high inductance motors (standard AC 230V servo motors)
The following user(s) said Thank You: dkraft
Moderators: PCW, jmelson
Time to create page: 0.064 seconds
