8i20
4 years 7 months ago #236225 by dkraft
Replied by dkraft on topic 8i20
yes. I thought I'd be clever and debug with a low inductance motor, didn't work. got it working with a washing machine motor though..
Moving on to the yaskawa servo motors now.
Your help with the commutation signals was crucial. Thank You.
Last piece was bldc.init ;)
4 years 7 months ago #237321 by dkraft
How can I get my encoder offset ?
I'm thinking it's aligned with the "U+, VW-" method, then average the 6 positions found modulus encoder scale / poles...
(I hacked a CMT102 on a servo with 6 poles)
4 years 7 months ago #237325 by andypugh
Replied by andypugh on topic 8i20
One not-very-scientific way to get the encoder offset is to just guess it until the motor runs at the same speed in both directions with a low drive current.
The u+ VW- method is the best way, but it's not so easy to do that with an 8i20 as it adds in a phase angle.
If you can connect the servo to a power supply on the bench, then your idea will work. Set the "index-enable" of the encoder counter, turn it by hand through the reset, and then look at the encoder counts and take the modulus, as you suggest.
It is likely to be zero, or very close to zero.
The following user(s) said Thank You: dkraft
4 years 7 months ago #237632 by dkraft
Why are my outputs all "spikey" ?
4 years 7 months ago #237640 by andypugh
What does your rotor position feedback look like? (probably encoder.0.position)
Also look at the encoder velocity.
4 years 7 months ago - 4 years 7 months ago #237659 by dkraft
So I reduced the encoder counts from 8192 (which were clean - not spikey) to 1536 ppr, because I doubt 8192 x 3000rpm on three axis is gonna be kept up with anyway...
Still getting a non-smooth motion in two dimensions - tiny reactions to encoder inputs and some kind of long sinusoidal that I guess is from the motor cogging on 80% power.... Is the pid not smoothing though ? or is my I too low?
High speed pass.
Is the pid overreacting for some reason ?
Last edit: 4 years 7 months ago by dkraft. Reason: added high speed pass
Moderators: PCW, jmelson
Time to create page: 0.101 seconds
