8i20
4 years 8 months ago #236140 by dkraft
Replied by dkraft on topic 8i20
sheez - so picky! (that was it.)
Here's the reason I'm after that -
Every time I init, the drive faults no matter how low I set the current-maxlim
If I Disconnect two leads to the motor, of course it doesn't.
How can I troubleshoot this? am I understanding the current limits?
Thanks!
36 float RW 1 hm2_7i95.0.8i20.0.0.angle-maxlim
36 float RW 0 hm2_7i95.0.8i20.0.0.angle-minlim
36 float RW 1 hm2_7i95.0.8i20.0.0.angle-scalemax
36 float RW 655.35 hm2_7i95.0.8i20.0.0.bus-voltage-scalemax
36 float RW 65535 hm2_7i95.0.8i20.0.0.card-temp-scalemax
36 float RW 1.5 hm2_7i95.0.8i20.0.0.current-maxlim
36 float RW -1.5 hm2_7i95.0.8i20.0.0.current-minlim
36 float RW 7.5 hm2_7i95.0.8i20.0.0.current-scalemax
36 u32 RW 0x000088B8 hm2_7i95.0.8i20.0.0.nvbrakeoffv
36 u32 RW 0x00009088 hm2_7i95.0.8i20.0.0.nvbrakeonv
36 u32 RW 0x00009664 hm2_7i95.0.8i20.0.0.nvbusoverv
36 u32 RW 0x00001194 hm2_7i95.0.8i20.0.0.nvbusundervmax
36 u32 RW 0x00000DAC hm2_7i95.0.8i20.0.0.nvbusundervmin
36 u32 RW 0x00000000 hm2_7i95.0.8i20.0.0.nvkdihi
36 u32 RW 0x00007D00 hm2_7i95.0.8i20.0.0.nvkdil
36 u32 RW 0x0000C350 hm2_7i95.0.8i20.0.0.nvkdilo
36 u32 RW 0x00000032 hm2_7i95.0.8i20.0.0.nvkdp
36 u32 RW 0x00000000 hm2_7i95.0.8i20.0.0.nvkqihi
36 u32 RW 0x00007D00 hm2_7i95.0.8i20.0.0.nvkqil
36 u32 RW 0x0000C350 hm2_7i95.0.8i20.0.0.nvkqilo
36 u32 RW 0x00000032 hm2_7i95.0.8i20.0.0.nvkqp
36 u32 RW 0x000002EE hm2_7i95.0.8i20.0.0.nvmaxcurrent
36 u32 RW 0x00000009 hm2_7i95.0.8i20.0.0.nvrembaudrate
36 u32 RO 0x0000008B hm2_7i95.0.8i20.0.0.swrevision
36 u32 RO 0x0A00010B hm2_7i95.0.8i20.0.0.unitnumber
4 years 8 months ago #236141 by PCW
Replied by PCW on topic 8i20
What actual fault are you getting?
It looks like there are no communications because the bus voltage
and temperature are wrong/crazy
4 years 8 months ago #236143 by dkraft
Its the hm2_7i95.0.8i20.0.0.fault.overcurrent
I'm able to see 0 serial faults.
It still reports position and realtime pin on show hal configuration.
It recovers upon linuxcnc restart.
It "tings" the motor when it happens.
I'm able to put a 1ohm 100watt resistor on one leg (which quickly gets hot!) but it sings - indicating some kind of AC modulation.
Open voltage on the motor leg power is nominally within range of input voltage (77 volts)
exchanged 8i20 modules does same thing.
4 years 8 months ago #236144 by dkraft
loadrt [KINS]KINEMATICS
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10"
loadrt pid names=pid.x,pid.y,pid.z,pid.s
loadrt bldc cfg=q,q,q
addf [HMOT](CARD0).0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf bldc.0 servo-thread
addf bldc.1 servo-thread
addf bldc.2 servo-thread
addf [HMOT](CARD0).0.write servo-thread
# external output signals
# external input signals
# AXIS X JOINT 0
setp [HMOT](CARD0).0.8i20.0.0.current-maxlim 0.020
setp [HMOT](CARD0).0.8i20.0.0.current-minlim -0.020
newsig emcmot.0.enable bit
sets emcmot.0.enable FALSE
net emcmot.0.enable => [HMOT](CARD0).0.8i20.0.0.fault.no-enable-not
net emcmot.0.enable <= pid.x.enable
# -- BLDC setup --
setp bldc.0.initvalue 0.2
setp bldc.0.drive-offset 0
setp bldc.0.rev 0
setp bldc.0.lead-angle 45
#setp bldc.0.encoder-offset 0
setp bldc.0.poles 8
setp bldc.0.scale -8192
setp pid.x.Pgain [JOINT_0]P
setp pid.x.Igain [JOINT_0]I
setp pid.x.Dgain [JOINT_0]D
setp pid.x.bias [JOINT_0]BIAS
setp pid.x.FF0 [JOINT_0]FF0
setp pid.x.FF1 [JOINT_0]FF1
setp pid.x.FF2 [JOINT_0]FF2
setp pid.x.deadband [JOINT_0]DEADBAND
setp pid.x.maxoutput [JOINT_0]MAX_OUTPUT
setp pid.x.error-previous-target true
#net x-pos-rawcounts bldc.0.rawcounts
#net x-bldc-current bldc.0.out
net x-meas-angle bldc.0.phase-angle
#net x-output bldc.0.value
net x-index-enable <=> pid.x.index-enable
#net x-enable => pid.x.enable
#net x-pos-cmd => pid.x.command
net x-pos-fb => pid.x.feedback
#net x-output <= pid.x.output
# position command signals
net emcmot.00.pos-cmd joint.0.motor-pos-cmd => pid.x.command
net motor.00.command pid.x.output => bldc.0.value
net motor.00.current bldc.0.out => [HMOT](CARD0).0.8i20.0.0.current
# commutation angle signals
net motor.00.rawcounts [HMOT](CARD0).0.encoder.00.rawcounts => bldc.0.rawcounts
#net motor.00.index-enable [HMOT](CARD0).0.encoder.00.index-enable => bldc.0.index-enable
net motor.00.angle bldc.0.rotor-angle => [HMOT](CARD0).0.8i20.0.0.angle
setp [HMOT](CARD0).0.encoder.00.counter-mode 0
setp [HMOT](CARD0).0.encoder.00.filter 1
setp [HMOT](CARD0).0.encoder.00.index-invert 0
setp [HMOT](CARD0).0.encoder.00.index-mask 0
setp [HMOT](CARD0).0.encoder.00.index-mask-invert 0
setp [HMOT](CARD0).0.encoder.00.scale [JOINT_0]ENCODER_SCALE
net x-pos-fb <= [HMOT](CARD0).0.encoder.00.position
net x-vel-fb <= [HMOT](CARD0).0.encoder.00.velocity
net x-pos-fb => joint.0.motor-pos-fb
#net x-pos-rawcounts <= [HMOT](CARD0).0.encoder.00.rawcounts
# ---setup home / limit switch signals---
net x-home-sw => joint.0.home-sw-in
net x-neg-limit => joint.0.neg-lim-sw-in
net x-pos-limit => joint.0.pos-lim-sw-in
4 years 8 months ago - 4 years 8 months ago #236145 by PCW
Does the init cycle run without fault?
What I am getting at is that you may get faults due to instability,
either in LinuxCNCs PID = LinuxCNC PID tuning issues or in the 8I20.
If you cannot set a static current in the 8i20 without fault, its likely the
8I20s current loop PI gains are too high for your motor.
Last edit: 4 years 8 months ago by PCW.
The following user(s) said Thank You: dkraft
4 years 8 months ago #236146 by andypugh
Replied by andypugh on topic 8i20
Is this just for testing? I have forgotten how the calculations work, but this seems odd.
I run both my machines with 8i20, but as they have resolvers the configs won't transfer straight across.
net x-meas-angle bldc.0.rotor-angle => hm2_5i23.0.8i20.0.2.angle setp hm2_5i23.0.8i20.0.2.current-maxlim 7.5 setp hm2_5i23.0.8i20.0.2.current-minlim -7.5 net x-cmd joint.0.motor-pos-cmd => pid.0.command net x-vel-cmd joint.0.vel-cmd => pid.0.command-deriv net x-fb hm2_5i23.0.resolver.01.position pid.0.feedback joint.0.motor-pos-fb net x-vel-fb hm2_5i23.0.resolver.01.velocity pid.0.feedback-deriv setp hm2_5i23.0.resolver.01.velocity-scale -1 net x-pid pid.0.output => hm2_5i23.0.8i20.0.2.current #12 motor 49 pulley 5 leadscrew pitch setp hm2_5i23.0.resolver.01.scale -1.2244898 net amp-enable-and-DC-good pid.0.enable setp pid.0.Pgain [JOINT_0]PGAIN setp pid.0.Igain [JOINT_0]IGAIN setp pid.0.Dgain [JOINT_0]DGAIN setp pid.0.bias [JOINT_0]BIAS setp pid.0.FF0 [JOINT_0]FF0 setp pid.0.FF1 [JOINT_0]FF1 setp pid.0.FF2 [JOINT_0]FF2 setp pid.0.deadband [JOINT_0]DEADBAND setp pid.0.maxoutput [JOINT_0]MAXOUTPUT setp bldc.0.scale -16777216 setp bldc.0.poles 6 setp bldc.0.lead-angle 0 setp bldc.0.encoder-offset -950000
Try with the max and min current matching the nvmaxcurrent (7.5A = 0x2EE, which you seem to have)
Moderators: PCW, jmelson
Time to create page: 0.193 seconds
