Need help to wire and config Mesa 7i92TM
- CollieBabaX
30 Mar 2022 22:12 #238841
by CollieBabaX
Replied by CollieBabaX on topic Tips for noob, and USB BOB BL-USBMach-v2.1 compatibility
Ok found. At this point I could take a 7i92h so I use two identical cables and two breakout boards.
- Thank you received: 6936
30 Mar 2022 22:39 #238845
Replied by tommylight on topic Tips for noob, and USB BOB BL-USBMach-v2.1 compatibility
Yup those should do just fine.
- Thank you received: 4966
30 Mar 2022 23:33 #238850
Replied by andypugh on topic Tips for noob, and USB BOB BL-USBMach-v2.1 compatibility
- CollieBabaX
31 Mar 2022 16:33 #238927
by CollieBabaX
Well guys, thank you very much for the help.
I took a closer look at the LinuxCNC documentation and saw a bit how to set up a new machine.
Now I have to buy the cards and then I will try to connect and configure everything
I will certainly have other questions and before poweing the board I will ask you for a confirmation on the wiring.
Thanks again
Thanks again
- CollieBabaX
26 May 2023 21:07 #272230
by CollieBabaX
Hi guys, it's been a while but now I have everything I need (I hope).
I bought a Mesa 7i92TM and installed LinuxCNC 2.8.4 Debian 10 Buster PREEMPT-RT ISO on my computer.
But I don't understand which are the correct settings in the configuration wizards on LinuxCNC.
Should I use Pncconf since it's a Mesa board or should I use Stepconf since I have two generic BOBs? (see attached picture)
Thank you
Thank you
26 May 2023 21:27 #272231
PncConf.
StepConf is for parallel port, you are not using a parallel port.
- CollieBabaX
26 May 2023 21:49 #272232
by CollieBabaX
Ok, at point "Mesa Card 0" on "Board name " I select "7i92 - Internal data", but on "Firmware" what should I select? There are only BOB Mesa on the list.
- Thank you received: 5193
26 May 2023 22:19 - 26 May 2023 22:20 #272234
Replied by PCW on topic Tips for noob, and USB BOB BL-USBMach-v2.1 compatibility
I would use a parallel port pinout compatible firmware like G540x2
Note that those are just physical breakouts without any output buffering
or input protection so you need to be quite careful with connections to
your machine as any even instantaneous connection to a voltage above +7V
or below -0.7V will damage the 7I92xx
Last edit: 26 May 2023 22:20 by PCW.
- CollieBabaX
26 May 2023 22:37 #272236
by CollieBabaX
Ok thanks for the warning, I'll be careful.
It says there are 34 pins in the G540, but in my BOB there are only 25 pins + GND. And the numbers in the I/O Connector don't match.
26 May 2023 22:48 #272238
There are 25 pins per 7I92 connector (17 are I/O bits and 8 are ground)
so with both connectors, you have 34 I/O total I/O bits
Note that your DB25 adapter pinout matches the pinout printed by mesaflash
or the .pin files included with the 7I92T firmware
(though the GND pins = 18..25 are not shown)
Time to create page: 0.146 seconds
