Does Mesa 5I24-25 would work on PCIe 2.0 x16
- yrsiddhapura
- Thank you received: 5
25 Jun 2022 09:00 #245846
by yrsiddhapura
Does Mesa 5I24-25 would work on PCIe 2.0 x16 was created by yrsiddhapura
Greetings,
I am planing to purchase some mesa board but due to unavailability of ethernet based FPGA board i am planning purchase Mesa 5I24-25 and it based on PCI Card but PC(Dell Optiplex 790 SFF) i bought for this project is having PCIe 2.0 x16 so does 5I24 would work with PCIe X16 slot or i will required any adapter ?
And Does it will effect on performance ? And is Ethernet board are any better then PCI based ?
- Thank you received: 7488
25 Jun 2022 10:03 #245849
Replied by tommylight on topic Does Mesa 5I24-25 would work on PCIe 2.0 x16
There are PCI to PCI-E adapter boards, but i doubt you can fit them inside an SFF case.
Not much diference betwen ethernet and PCI/PCI-E, except for plasma, easier to arange stuff to protect from interference.
Performance is the same.
The following user(s) said Thank You: yrsiddhapura
- billykid
- Thank you received: 83
25 Jun 2022 12:02 #245850
by billykid
Replied by billykid on topic Does Mesa 5I24-25 would work on PCIe 2.0 x16
Right Tom, but in case of closed loop and fast servo threads the pci is much better ... I have an i7 with 5i23 reaches 20 khz without problems. i think ethernet stops much sooner.
25 Jun 2022 12:43 #245852
Really?
Well i know they can all do abut 4KHz, but 20, that is niceeee.
Although i never had a need for anything over 1KHz on closed loop servos.
Do you have Torque mode drives, that might need faster servo period.
- billykid
25 Jun 2022 14:33 #245857
by billykid
I have the 7i40 hv which is practically halfway between speed and torque I was told, it goes at 8khz. the one that goes to 20 is the i7 of the plasma with 7i30, but I had to put it back to 4khz because the thc from standstill was jerking of 2 volts ... probably could not follow. however it is done to try at 4khz we are already in place
- yrsiddhapura
26 Jun 2022 09:04 #245902
by yrsiddhapura
Replied by yrsiddhapura on topic Does Mesa 5I24-25 would work on PCIe 2.0 x16
Thank you so muchThere are PCI to PCI-E adapter boards, but i doubt you can fit them inside an SFF case.
- hoffb77
- Thank you received: 21
26 Jun 2022 16:51 - 26 Jun 2022 16:52 #245936
by hoffb77
Replied by hoffb77 on topic Does Mesa 5I24-25 would work on PCIe 2.0 x16
Last I looked Mesa still has seven 7i96s boards in stock. They are set up for plasma in mind. Its a 5v board with isolated i/o. Two of them AC ready. We got a couple and I like them. You will need 2.9 installed from buildbot though.
Mesa 7i96s
Mesa 7i96s
Last edit: 26 Jun 2022 16:52 by hoffb77.
- JT
- Thank you received: 593
26 Jun 2022 22:57 #245964
by JT
Replied by JT on topic Does Mesa 5I24-25 would work on PCIe 2.0 x16
I have 7i96S and THCAD cards in stock as well.
Don't forget to use my Mesa Configuration Tool , it's the only one that can make a configuration for the 7i96S.
JT
JT
- yrsiddhapura
30 Jun 2022 09:35 #246261
by yrsiddhapura
Well i am going to converting a conventional horizontal boring mill (Union BFT90/3) to CNC HBM with dual encoder feed back so i have to setup something that could handle 6 Step/Dir( 5 Axis + 1 Spindle) and 11 Encoder Feedback ( 6 Velocity and 5 Position) and and about 90 input and 40 output so originally i have planed to with 7I80HD-25 + 7I52S + 7I52 + 7I84D(X3) OR 6I24-25 + 7I52S + 7I52 + 7I84D(X3) but unfortunately 7I80HD-25 and 6I24-HD both are unavailable.
30 Jun 2022 09:39 #246262
Time to create page: 0.111 seconds
