7i97 hookup help
4 years 3 months ago #247155 by PCW
Replied by PCW on topic 7i97 hookup help
No, there is no power supply involved on the inhibit side
(If grounding the inhibit line disables the drives)
Relay NC ---> Drive Inhibit
Relay COM -->Drive GND
4 years 3 months ago #247162 by JPL
Replied by JPL on topic 7i97 hookup help
And you're are basically shorting your power supply by doing it this way image missing /media/kunena/emoticons/w00t.png
See: The NC and COM contact from your relay are normally closed (eg. connected together inside the relay) . The full circuit you have is: 12V+  --> Relay NC --> Relay COM --> ground.  This is doing the very same as connecting directly the 12v+ to ground  (Pouf!!!)... Unless, of course, the relay is being kept activated. (Then Pouf!!! once the relay is deactivated)
4 years 3 months ago #247165 by Kylizer
Replied by Kylizer on topic 7i97 hookup help
Like this?
4 years 3 months ago - 4 years 3 months ago #247168 by PCW
No, the relay NC and COM contacts connect to
the drives inhibit and GND and no flyback diode is used there.
There is no connection at all from the drive to the ENA lines,
the ENA lines are used to drive the relay coil (the relay coil has the flyback installed)
I will try and draw a simple schematic later today
Last edit: 4 years 3 months ago by PCW.
4 years 3 months ago - 4 years 3 months ago #247178 by PCW
Note that diode polarity is critical (band to +12V) , you will damage the 7I97 if it is installed backwards
Your browser does not support embedded PDFs. Please download the file here: Download PDF.
Note that the relay pin numbers are meaningless unless you are using an identical relay
4 years 3 months ago #247233 by Kylizer
Can that relay be a SPDT? Also I’m not familiar with electrical symbols and was wondering where it’s showing to hook to on the relay. NC, NO, and Common. This is what’s on my SPDT relays anyway. If this won’t work I will purchase the DPDT
Moderators: PCW, jmelson
Time to create page: 0.363 seconds
