7i97 hookup help
4 years 3 months ago #247683 by PCW
Replied by PCW on topic 7i97 hookup help
Does the relay click when you short the ENA pins?
are the drives then enabled?
4 years 3 months ago #247793 by Kylizer
Replied by Kylizer on topic 7i97 hookup help
Sheesh. Ok so I tried that and no it does not click the relay only the red light comes on but......... I may need to back track and see that everything is wired right because for some reason 1 of the 3 amps is coming on when I have the 4 pin enable/analog unplugged, yet the other 2 are off and the thing is that they are all tied together sooooo? Maybe the one that runs the z is set up different??? Ill double check it all and get that part worked out then see about this relay situation.
Moderators: PCW, jmelson
Time to create page: 0.297 seconds
