7I76 output issue
4 years 3 months ago #247484 by 42walrustitan
Replied by 42walrustitan on topic 7I76 output issue
My only spindle control is going to be on off because the spindle is a hand held router controlled through a relay. As far as I know I have set up the spindle in pncconf. Is there something special I need to do to set it up.
4 years 3 months ago #247485 by PCW
Replied by PCW on topic 7I76 output issue
If you want to use a field output to drive the relay,
you would set that up in pncconf, something like this:
(output 01 is spindle- on)
4 years 3 months ago #247501 by 42walrustitan
That is what I did. Is there something else that I need to do?
4 years 3 months ago #247506 by PCW
If you did, you should get a statement like
net spindle-enable => [HMOT](CARD0).7i76.0.0.output-01
in your hal file
If thats is there the 7I76 output01 will turn on when the spindle is enabled
4 years 3 months ago #247736 by 42walrustitan
Where in the HAL file will that be. I see a lot of similar things
4 years 3 months ago #247737 by PCW
Normally these would be near the top of the hal file, but in any case
using the editors search function will find it (search for "output-01" for example)
Moderators: PCW, jmelson
Time to create page: 0.060 seconds
