7i76E Stock ?
- my1987toyota
- Thank you received: 449
12 Oct 2022 17:29 #254023
by my1987toyota
Replied by my1987toyota on topic 7i76E Stock ?
and gone. I guess we wont see anymore 7i76E's until the new design comes out.
- Thank you received: 7491
12 Oct 2022 19:08 #254030
Replied by tommylight on topic 7i76E Stock ?
What happened?
- my1987toyota
12 Oct 2022 23:12 #254043
by my1987toyota
MESA sold out of them again. The FPGA that the board has been designed with is extremely
expensive now and from what I understand a replacement board is in the works with a different
FPGA chip.
FPGA chip.
12 Oct 2022 23:20 #254044
Did you get some a few days back?
You wanted more?
I am getting low on Mesa also, and since we are here, PCW, is there a firmware for 7i95 with 7i77? I do not need it right now, but i might have to return the 7i92 to the machine i borrowed it from.
You wanted more?
The following user(s) said Thank You: my1987toyota
- my1987toyota
12 Oct 2022 23:29 #254045
by my1987toyota
13 Oct 2022 00:38 #254049
And right now i really really need a 7i72, like right now, not after a month. By then i will cobble together some 30 odd inverted outputs!
People collect old strange paintings, i collect Mesa boards!This Linuxcnc stuff is an addiction.
- my1987toyota
13 Oct 2022 21:22 #254088
by my1987toyota
I didn't check my email for a few days ( long days too tired ). It was only Later that I found out the 2nd
order got canceled because I didn't confirm in time. Unfortunately Mesa is not going to have the
7i76E in stock until the new design is out.
or at least I thought I had got two more ordered before they ran out. I had been so busy at work thatYes. I got the 2 ordered that I needed plus 2 more for a couple other machines I have my eye on.
- my1987toyota
14 Oct 2022 10:54 #254109
by my1987toyota
Hey Tommylight I see EUsurplus has some 7i72's in stock. I am not sure if customs would be
the limiting factor time wise.
14 Oct 2022 12:17 #254111
I did not bother to check, currently i am totally broke, and i caused plenty of work for eusurplus last order as it was returned to sender so they had to mail it again in two boxes. They are very, very good so i try not to bother them.
I already started making some inverters as i had over 40 of 2N2222 transistors, but i have only 14 of 2.7KOhm resistors, sooo.....
More diving through the shop !
- my1987toyota
14 Oct 2022 21:00 #254132
by my1987toyota
that and a nice piece of perf-board.
Time to create page: 0.222 seconds
