- Thank you received: 158
Yeah, it seems shielded motor cables (as well as IO cables) is the standard? Even my old Yaskawa SGDA manual (from the 1990's) shows shielded motor cables (both power and encoder).You mention "shielded" so my favoured Neutrik (SpeakCON and PowerCON) won't work.
I looked through the catalog and it seems these are meant to be used on the motors exclusively - there are no versions of the mains voltage rated connectors with female receptacles? AND they require a €1000 (€969.19 to be exactI used M23 to pass the power and feedback for the 4th axis through the mill to allow it to be disconnected.
The contacts may have ok voltage and current ratings, but the wimpy solder cups surely aren't suitable for mains voltage? Also, max 0.5 mm² cables.And, that mention of D-sub brings me to the real point of this reply. Ordinary D-sub have a higher current and voltage rating than you might guess:
docs.rs-online.com/869a/A700000007669880.pdf
750V and 5A, and it's not a fancy one.
