My notes flashing LiteX-CNC on a Colorlight 5A-75E (solved)
17 Oct 2022 20:41 - 19 Oct 2022 06:59 #254359 by DePrutser
That works:
[root@cedric cedric]# pacman -S openfpgaloader
[cedric@cedric ~]$ openFPGALoader -c usb-blaster -m LiteX-CNC/5a-75e/gateware/colorlight_5a_75e.bit
write to ram
Open file: DONE
Parse file: DONE
Enable configuration: DONE
SRAM erase: DONE
Loading: 100.00%
Done
Disable configuration: DONE
[cedric@cedric ~]$
Last edit: 19 Oct 2022 06:59 by DePrutser.
The following user(s) said Thank You: MartijnD
06 May 2023 13:58 - 06 May 2023 13:59 #270796 by MartijnD
@DePrutser, Thanks for making these logs. they helped me a lot.
As an addition I can tell that a "ESP-prog" worked for well for me.
Can you tell me how you loaded the LiteX-CNC driver in LinuxCNC?
Last edit: 06 May 2023 13:59 by MartijnD.
Moderators: PCW, jmelson
Time to create page: 0.094 seconds
