My notes flashing LiteX-CNC on a Colorlight 5A-75E (solved)
01 Oct 2022 16:16 - 01 Oct 2022 16:20 #253186 by DePrutser
Hi All,
In this thread I'm documenting my attempts to flash LiteX-CNC firmware [6] on my Colorlight 5A-75E [1].
I have the following programmers:
USB Blaster (ALTERA CPLD / FPGA download cable) [2]
Cmsis Dap/Daplink Emulator STM32 Debug Probe [3]
Pi Pico Board RP2040 [4]
CKS32F103C8T6 STM32F103C8T6 ARM STM32 Minimum System Development Board Module [5]
Any suggestions on what software is available is welcome.
[1] github.com/q3k/chubby75/tree/master/5a-75e
[2] www.aliexpress.us/item/2251800524323433.html
[3] nl.aliexpress.com/item/1005002784627064.html
[4] www.aliexpress.us/item/3256804322303962.html
[5] www.aliexpress.us/item/2251801562130385.html
[6] github.com/cdwijs/LiteX-CNC/tree/expanded-readme
Last edit: 01 Oct 2022 16:20 by DePrutser. Reason: Forgot a programmer
The following user(s) said Thank You: andypugh
02 Oct 2022 15:00 #253257 by DePrutser
First contender: The Altera USB Blaster.  The pinout of the 10-pin cable is like this, the difference between the different sources is denoted by "|":
[1]  [2] [3]
1 TCK | TRGTCK
2 GND
3 TDO | TRGTDO
4 VTref | VCC(TRGT) | TRGVCC
5 TMS | TRGTMS
6 nSRST | PROC_RST
7 Vsupply| -
8 (nTRST) | -
9 TDI | TRGASDO
10 GND
For the Colorlight 75E, the pins TDO, TDI, TMS, TCK, 3v3 and GND are used [4], so the required connections are like this:
COLORLIGHT 75E - signal - USB Blaster
J30 - TDO - 3
J32 - TDI - 9
J31 - TMS - 5
J27 - TCK - 1
J33 - 3v3 - 7
J34 - GND - 2,10
[1] www.digital-circuitry.com/IMAGES/webpage...ster_JTAG_pinout.jpg
[2] www.intel.com/content/dam/support/jp/ja/...b-blstr-ii-cable.pdf page 2-3
[3] www.terasic.com.tw/wiki/Terasic_USB_Blaster_revB_Manual
[4] github.com/q3k/chubby75/tree/master/5a-75e
06 Oct 2022 18:58 #253629 by DePrutser
It looks like i need openocd, with 2 config files. One for the Altera USB Blaster, and the other for the ECP5 FPGA.
here [1] they suggest this for the file "ecp5.ocd"
# file: ecp5.ocd
telnet_port 4444
gdb_port 3333
# JTAG TAPs
jtag newtap lfe5 tap -expected-id 0x21111043 -irlen 8 -irmask 0xFF -ircapture 0x5
# -expected-id should match ECP5 CHIP_ID:
# 12F: 0x21111043
# 25F: 0x41111043
# 45F: 0x41112043
# 85F: 0x41113043
init
scan_chain
svf -tap lfe5.tap -quiet -progress bitstream.svf
shutdown
here [2] they suggest they suggest this for the file "openocd.cfg"
interface usb_blaster
jtag_khz 1000
jtag newtap ep3c25f324 tap -irlen 10 -expected-id 0x020f30dd
init
svf led/led.svf quiet
here [3] they specify this:
# ecp3.cfg
# OpenOCD commands
telnet_port 4444
gdb_port 3333
# JTAG TAPs
jtag newtap lfe5u25 tap -expected-id 0x41111043 -irlen 8 -irmask 0xFF -ircapture 0x5
#jtag newtap lfe5u45 tap -expected-id 0x41112043 -irlen 8 -irmask 0xFF -ircapture 0x5
#jtag newtap lfe5u85 tap -expected-id 0x41113043 -irlen 8 -irmask 0xFF -ircapture 0x5
init
scan_chain
svf -tap lfe5u25.tap -quiet -progress project/project_project_sram.svf
shutdown
From here [4] I get the impression openocd is capable of autodetecting an JTAG tap port:
my_vsllink.cfg:
interface vsllink
vsllink_usb_vid 0x0483
vsllink_usb_pid 0x5740
adapter_khz 100
transport select jtag
In the terminal:
openocd -f my_vsllink.cfg
Open On-Chip Debugger 0.10.0
Licensed under GNU GPL v2
For bug reports, read
openocd.org/doc/doxygen/bugs.html
adapter speed: 100 kHz
jtag
Info : Versaloon(0x15)by Simon(compiled on Dec 20 2018)
Info : USB_TO_XXX abilities: 0x0000176E:0x010001EF:0xC0000007
Info : clock speed 100 kHz
Warn : There are no enabled taps. AUTO PROBING MIGHT NOT WORK!!
Info : JTAG tap: auto0.tap tap/device found: 0x44002093 (mfg: 0x049 (Xilinx), part: 0x4002, ver: 0x4)
Warn : AUTO auto0.tap - use "jtag newtap auto0 tap -irlen 2 -expected-id 0x44002093"
Error: IR capture error at bit 2, saw 0x3FFFFFFFFFFFFFF5 not 0x...3
Warn : Bypassing JTAG setup events due to errors
Warn : gdb services need one or more targets defined
I'm not sure yet what the correct commands and config files for openosc are, but I'm getting closer.
[1] github.com/emard/ulx3s/blob/master/doc/MANUAL.md
[2] forum.sparkfun.com/viewtopic.php?t=22458
[3] github.com/f32c/f32c/blob/master/rtl/pro...d/ulx3s/ecp5-25f.ocd
[4] github.com/zoobab/versaloon
07 Oct 2022 05:41 #253644 by DePrutser
First test using my usb blaster.
$ cat myopenocd.cfg
adapter driver usb_blaster
$ openocd -f ./myopenocd.cfg
Open On-Chip Debugger 0.11.0
Info : only one transport option; autoselect 'jtag'
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : No lowlevel driver configured, using ftdi
Info : usb blaster interface using libftdi
Info : This adapter doesn't support configurable speed
Error: JTAG scan chain interrogation failed: all ones
Error: Check JTAG interface, timings, target power, etc.
Error: Trying to use configured scan chain anyway...
^Cshutdown command invoked
The same command without the usb blaster connected:
Error: unable to open ftdi device: device not found
Looks like the usb blaster has been found. Next step is to connect the colorlight board.
07 Oct 2022 21:24 #253717 by DePrutser
I have connected the colorlight board to the usb blaster, and the fpga is detected, but I do get an IR capture error:
Info : JTAG tap: auto0.tap tap/device found: 0x41111043 (mfg: 0x021 (Lattice Semi.), part: 0x1111, ver: 0x4)
Warn : AUTO auto0.tap - use "jtag newtap auto0 tap -irlen 2 -expected-id 0x41111043"
Error: IR capture error at bit 2, saw 0x3fffffffffffff05 not 0x...3
07 Oct 2022 21:36 #253718 by DePrutser
Here[1] i see the following openosc output while flashing a colorlight FPGA board. Notice the irlen is 8 and not the 2 in my output:
$ sudo openocd -f interface/vsllink.cfg -f chubby.cfg
adapter speed: 200 kHz
Info : Versaloon(0x15)by Simon(compiled on Jul 26 2020)
Info : USB_TO_XXX abilities: 0x00000208:0x010001E3:0xC0000007
Info : clock speed 200 kHz
Info : JTAG tap: lfe5u25.tap tap/device found: 0x41111043 (mfg: 0x021 (Lattice Semi.), part: 0x1111, ver: 0x4)
TapName Enabled IdCode Expected IrLen IrCap IrMask
0 lfe5u25.tap Y 0x41111043 0x41111043 8 0x05 0xff
svf processing file: "top.svf"
95%
Time used: 0m50s625ms
svf file programmed successfully for 620 commands with 0 errors
[1] forum.1bitsquared.com/t/colorlight-5a-75...lopment-platform/141
07 Oct 2022 21:38 #253719 by DePrutser
Now I don't get an error anymore, but I don't know if it actually works yet:
$ cat myopenocd.cfg
jtag newtap auto0 tap -irlen 8 -expected-id 0x41111043
12 Oct 2022 05:40 #254000 by DePrutser
I tried to flash the .lpf file I made using this guide [1] I can't get it to work yet:
[cedric@cedric ~]$ cat myopenocd.cfg
[cedric@cedric ~]$ cat colorlight_5a_75e.cfg
init
scan_chain
svf -progress colorlight_5a_75e.lpf
shutdown
[cedric@cedric ~]$ openocd -f ./myopenocd.cfg -f ./colorlight_5a_75e.cfg
svf processing file: "colorlight_5a_75e.lpf"
0% BLOCK RESETPATHS;
Error: invalid svf command: BLOCK
Error: fail to run command at line 1
Time used: 0m0s0ms
svf file programmed failed
[1] forum.linuxcnc.org/27-driver-boards/4692...itex-cnc-on-linuxcnc
12 Oct 2022 19:13 #254032 by DePrutser
It turns out the .lpf was not the actual FPGA bitstream. After generating the bitstream (see [1]), I still get an error, but I got a lot further:
$ cat myopenocd.cfg
init
scan_chain
svf -progress colorlight_5a_75e.svf
shutdown
svf processing file: "colorlight_5a_75e.svf"
0% HDR 0;
0% HIR 0;
0% TDR 0;
0% TIR 0;
0% ENDDR DRPAUSE;
0% ENDIR IRPAUSE;
0% STATE IDLE;
0% SIR 8 TDI (E0);
0% MASK (FFFFFFFF);
0% SIR 8 TDI (1C);
0% FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF);
0% SIR 8 TDI (C6);
0% SDR 8 TDI (00);
0% RUNTEST IDLE 2 TCK 1.00E-02 SEC;
0% SIR 8 TDI (0E);
0% SDR 8 TDI (01);
0% SIR 8 TDI (3C);
0% MASK (0000B000);
0% SIR 8 TDI (46);
0% SDR 8 TDI (01);
0% SIR 8 TDI (7A);
0% 0000DCFFFFFFFFCDBDFFFFFF006CAC4C82E24282C26CB462AC4CB4AAACA26232045C2E4E860A00FF);
0% 0000000000FF173300000000000000000000FF173300000000000000000000FF1733000000000000);
0% 0000FF173300000000000000000000FF173300000000000000000000FF1733000000000000000000);
<snip>
95% 00000000000000000000000000000000000000000000000000000000000000000000000000000000);
95% SIR 8 TDI (FF);
95% RUNTEST IDLE 100 TCK 1.00E-02 SEC;
95% SIR 8 TDI (C0);
95% RUNTEST IDLE 2 TCK 1.00E-03 SEC;
95% MASK (FFFFFFFF);
95% SIR 8 TDI (26);
95% RUNTEST IDLE 2 TCK 2.00E-01 SEC;
95% SIR 8 TDI (FF);
95% SIR 8 TDI (3C);
95% MASK (00002100);
Error: tdo check error at line 28
Error: READ = 0x0201f10
Error: WANT = 0x0000000
Error: MASK = 0x000b000
Time used: 0m1s761ms
[1] forum.linuxcnc.org/27-driver-boards/4692...on-linuxcnc?start=20
16 Oct 2022 21:06 #254260 by benitoss
I recommend to use OpenFPGALoader to program the ColorLight 5A-75E board. --> github.com/trabucayre/openFPGALoader
The reason is because you only need to work with bit files
The command line for usb-blaster is:
$ openFPGALoader -c usb-blaster -m my_bitstream.bit
For PI PICO board you need to use the DirtyJTAG proyect for PI PICO
github.com/phdussud/pico-dirtyJtag/
And the command line for OpenFPGALoader is :
$ openFPGALoader -c dirtyJtag -m my_bitstream.bit
Moderators: PCW, jmelson
Time to create page: 0.108 seconds
