Raspberry Pi 4 8Gb version 2 / Raspberry Pi OS 32-bit / Mesa 7c81 / Gecko G540
4 years 4 weeks ago #253282 by kdsands88
Who at LinuxCNC can help me with my questions about installing LinuxCNC on a raspberry Pi 4 8Gb version 2?
Also, when will a new release for Bullseye (that include a terminal and internet connect) be released that has direct support for Raspberry Pi 4 8Gb version 2 / Raspberry Pi OS 32-bit (or 64bit) / Mesa 7c81 / Gecko G540?  And not a work around Mesa 5I25+G540.
4 years 4 weeks ago - 4 years 4 weeks ago #253293 by kdsands88
Raspberry Pi 4B 8Gb
Raspberry Pi OS (64-bit) A port of Debian Bullseye (Released: 2022-09-22)
Error Message:
From Getting LinuxCNC
Last edit: 4 years 4 weeks ago by kdsands88. Reason: Can't attach screen shots
4 years 4 weeks ago #253294 by tommylight
For the 8GB Pi4 I would suggest starting again with the 64-bit SD card image on this forum: forum.linuxcnc.org/9-installing-linuxcnc...cnc?start=130#238020
The response did not answer my question on the error I received from following the directions on Getting LinuxCNC.
So you found it prudent to report him to the moderators, twice!
You are aware that this is a free forum, maintained and helped by members who get payed nothing for it, yet they consistently offer help to anyone who needs it, whenever and however they can?
The video you linked to explicitly mentions that version 1.5 and up do not work with software made for versions up to 1.4, and the error you are getting points to the kernel failing to install, be it due to bad download or the kernel not made for the environment in use.
4 years 4 weeks ago #253295 by andypugh
Broken Pipe sounds like the download of the package failed.
If the current Install instructions do not work then I can delete them.
4 years 4 weeks ago - 4 years 4 weeks ago #253302 by kdsands88
I have connected MESA for support. MESA is the company that sold the two boards to me. They are the ones that said LinuxCNC could help me with the software.
Continuing threating and not helping me will only get this website closed down.
Last edit: 4 years 4 weeks ago by kdsands88. Reason: spelling error
4 years 4 weeks ago #253303 by PCW
The pipe error could also be caused by a full drive, how much free disk space to you have?
Moderators: PCW, jmelson
Time to create page: 0.154 seconds
