7I84D and smoke
  • Moderator
  • Moderator
17 Oct 2022 20:45 #254361 by tommylight
Replied by tommylight on topic 7I84D and smoke
7i84 needs power connected to Vfield A also,
TB1  PIN     SIGNAL       FUNCTION
1 VFIELD B   FIELD POWER 5-32V for TB2 I/O (Bottom pin)
2 VFIELD B   FIELD POWER 5-32V for TB2 I/O
3 VFIELD A   FIELD POWER 5-32V for TB3 I/O
4 VFIELD A   FIELD POWER 5-32V for TB3 I/O
5 VINLOGIC   POWER 8-32V
6GROUNDVIN, VFIELD, COMMON
7GROUNDVIN, VFIELD, COMMON
8GROUNDVIN, VFIELD, COMMON (Top pin)
Note: When W1 is in the left hand position, VIN is connected to VFIELD B
18 Oct 2022 14:06 - 18 Oct 2022 14:11 #254419 by mgm
Replied by mgm on topic 7I84D and smoke
if I connect to pin3 (VieldA) +24V in addition to pin1 (VieldB) then the 7I76E does not start and there is smoke again at the power connector of the 7I84 !!!
what is wrong?
Last edit: 18 Oct 2022 14:11 by mgm.
18 Oct 2022 14:11 #254420 by PCW
Replied by PCW on topic 7I84D and smoke
Its likely one of the output driver chips was damaged by the reverse power connection
18 Oct 2022 14:37 #254425 by mgm
OK at inputs 0-15 is no function
so it is also clear why the display in the show hal configuration
is displayed inverted!
inputs 16-31 are working
the outputs I have not yet tested, but show in the show hal configuration all brown!
18 Oct 2022 15:11 #254431 by mgm
so outputs also tested
0-7 no function
8-15 OK
well i think i can do with 16 inputs and 8 outputs!
Moderators: PCW, jmelson
