Mesa Control Board Availability
- LinuxHurco
01 Nov 2022 12:31 #255657
by LinuxHurco
Mesa Control Board Availability was created by LinuxHurco
Hi All,
I am based in the UK and looking into a MESA card (preferably ethernet) such as the 7176E.
Does anyone know when these boards will be available again?
I have tried to contact MESA directly but have not yet had a reply.
Many thanks!
Many thanks!
- JT
- Thank you received: 595
01 Nov 2022 13:13 #255661
by JT
Replied by JT on topic Mesa Control Board Availability
The new 7i96S board is available.
mesaus.com/product/7i96s/
Shipping to UK is normally turned off unless requested.
JT
JT
The following user(s) said Thank You: LinuxHurco
- arvidb
- Thank you received: 158
01 Nov 2022 22:54 #255707
by arvidb
Replied by arvidb on topic Mesa Control Board Availability
You can get the 7i96S directly from Mesa though (shipping to UK enabled & cost estimated in the cart):
store.mesanet.com/index.php?route=produc...oduct&product_id=374
02 Nov 2022 00:55 #255731
Replied by andypugh on topic Mesa Control Board Availability
In Portugal, EUSurplus have some boards (but not the 7i76E).
The 6i25 / 7i76 combo is the PCIe equivalent if you are not wedded to the idea of ethernet.
eusurplus.com/index.php?route=product/category&path=59_62
- LinuxHurco
02 Nov 2022 10:42 #255772
by LinuxHurco
Replied by LinuxHurco on topic Mesa Control Board Availability
Thanks for the replies everyone! I decided to import a 7i96S from the US.
Looking forward to trying out the MESA board next week!
- JT
02 Nov 2022 12:08 #255780
by JT
Don't forget to use my Mesa Configuration Tool to build your configuration files. I just finished updating the tool so it does not change anything the user adds to the ini file which is a huge first for LinuxCNC as the other tools will write over the ini file and you will lose anything you added.
gnipsel.com/linuxcnc/mesact/index.html
In addition to the above the tool can perform many checks and report back many things about the PC as well as read and flash the board. It also has all the board manuals built in with diagrams for every board. It will also configure a smart serial daughter card and many other features. It will assist you in creating some basic custom HAL items. It can add MDI commands to [HALUI]...
JT
JT
The following user(s) said Thank You: arvidb, cngbrick, LinuxHurco
- automata
- Thank you received: 93
12 Nov 2022 06:47 #256490
by automata
Replied by automata on topic Mesa Control Board Availability
Do we know if any of the ethernet connected 50pin mesa cards or their replacements with the new FPGAs from Efinix are going to be available anytime soon i.e., 7i80HD-16, 7i80HD-25, 7i93?
-automata
-automata
- JT
12 Nov 2022 12:55 #256505
by JT
AFAIK the 7i92T series of boards are the next ones with the new FPGA. I don't know what's next.
JT
JT
- Thank you received: 5334
12 Nov 2022 14:44 - 12 Nov 2022 14:45 #256507
Replied by PCW on topic Mesa Control Board Availability
Current updated FPGA card order is:
7I92Tx Production cards at assembly
7I95T Proto cards at assembly
7I80HDT Artwork nearly done
7I76ET Design stage
(many changes including push-pull field outputs
so outputs can do sinking, sourcing or both
and require no flyback diodes)
7I76ET Design stage
Last edit: 12 Nov 2022 14:45 by PCW.
The following user(s) said Thank You: tommylight, Clive S, zack, cngbrick, snowgoer540, JT
- lkavan
- Thank you received: 3
13 Jun 2023 08:06 #273452
by lkavan
Replied by lkavan on topic Mesa Control Board Availability
Hallo,
please, have somebody an info about Mesa cards availability? Mesa not answering emails long time, eshop is still out of stock
If this platform is dead, is there any other similar hardware which can work with LinuxCNC?
Time to create page: 0.332 seconds
