Control of a vacuum pump
15 Dec 2022 08:39 - 15 Dec 2022 14:27 #259545 by mgm
Control of a vacuum pump was created by mgm
I got myself a vacuum pump which I now want to control with LCNC.
I have the following possibilities to connect it:
I have the following components:
- Mesa 7i76ED with 7i84D via RS422.
- Bit-file on the 7i76e is "7i76e_7i76x1_5abobpD".
- on P1 parallel expansion is connected a 7i75.
I need a 0-10V signal at the analog input (X10:3).
Can I do this with my Hardwear or do I need something additional?
TB4 of the 7i76ED is already occupied by the spindle!
Last edit: 15 Dec 2022 14:27 by mgm.
15 Dec 2022 22:34 #259594 by PCW
Replied by PCW on topic Control of a vacuum pump
Depending on whats connected to the 7I75, one possibility is to use
a "Mach 5 axis BOB" on P1, that would an additional analog output
16 Dec 2022 07:51 - 16 Dec 2022 08:05 #259613 by mgm
Replied by mgm on topic Control of a vacuum pump
At the 7i75 I have a PWM connected nothing else!
I still have a BOB ....
Do I have to change something in the bitfile?
Or would I have to replace the 7i75 with the BOB?
Last edit: 16 Dec 2022 08:05 by mgm.
20 Dec 2022 12:03 #259950 by mgm
Is it possible to run the 7i76ED and a Mach 5 axis BOB connected to the parallel port at the same time? to get an additional connection with 0-10V from the BOB.
20 Dec 2022 15:28 #259959 by PCW
Yes, you can connect a Mach 5 Axis BOB to one of the 7I76E expansion ports
and use 7i76e_7i76x1_5abobD.bit firmware.
20 Dec 2022 16:32 #259965 by mgm
I assume that it also works with this bit file!?!
7i76e_7i76x1_5abobpD.bit
20 Dec 2022 16:35 #259966 by PCW
Yes, that one replaces some of the 5ABOBs step/dir channels with PWM
20 Dec 2022 17:14 #259969 by mgm
and I can continue to use my 7i75?
so the 7i75 to P1 AND BOB to P2 is that right?
or do I have to remove the BOB at P1 and the 7I75 again?
The 7i75 is for the one PWM output!
But if you say that it replaces some Step/Dir then I can certainly connect a PWM to the Step/DIR!
20 Dec 2022 18:15 #259972 by PCW
You could use a PWM output from the BOB instead
The 7i76e_7i76x1_5abobpD.bit configuration has only GPIO on P2
(take a look at the .pin files for pinout information)
21 Dec 2022 01:16 #259989 by andypugh
Replied by andypugh on topic Control of a vacuum pump
Yes, you can run any combination of hardware, so you can run any number of parallel ports alongside any combination of Mesa cards.
Moderators: PCW, jmelson
Time to create page: 0.214 seconds
