Mesa 7I96S + 7I85S Bitfile
17 Dec 2022 00:19 #259693 by Stefan321
Replied by Stefan321 on topic Mesa 7I96S + 7I85S Bitfile
First of all, that sounds even better than what I wanted, and secondly, I don't quite understand the thing about the pins. I also have old Heidenhein glass scales that I believe are the difference and not ttl. is it also possible to mix?
the glass scales have 8 pins, 2 of which are for 5v and gnd.
17 Dec 2022 01:10 #259696 by PCW
Replied by PCW on topic Mesa 7I96S + 7I85S Bitfile
Yes, the 7I85S can interface to 4 encoders, individually selectable
as TTL or differential.
17 Dec 2022 01:39 #259697 by Stefan321
Thanks for all the information, I'm a lot smarter now. To be honest, before I buy something, I wanted to see if the hardware would do everything I wanted, and it does. Thanks for your help.
21 Dec 2022 20:07 #260037 by Stefan321
Hello,
my board arrived and i just wanted to flash it but it keeps saying "checking file...invalid bitfile header!". I'm a little clueless now
the file is 7i96s_7i85sd.bin?
21 Dec 2022 21:05 #260038 by PCW
Yes, that's the correct firmware file.
It's likely you need to update your copy of mesaflash:
github.com/LinuxCNC/mesaflash
(installation intsructions on bottom of page)
22 Dec 2022 00:03 #260053 by Stefan321
Hello,
So sign me up here again, it worked now. but had problems accessing websites where youtube worked. I think I have rights. either way I was able to download and install the github. I've already flashed and read out the mesa. everything is on now. Thanks again for all the help I think I'll have more questions in the future.
22 Dec 2022 12:00 #260074 by Stefan321
Hello,
so now i have another problem in the pncconfig there is not the right bit/bin file. However, when I try to install the mesa configuration tool, the error 404 not found comes directly with the first console command. And unfortunately I can't build a Hal completely myself.
  • Moderator
  • Moderator
22 Dec 2022 13:28 #260076 by tommylight
Replied by tommylight on topic Mesa 7I96S + 7I85S Bitfile
PncConf does not need those files for new Mesa cards, so just continue.
Moderators: PCW, jmelson
