7i97+7i85 bit file
- saquzi
18 Feb 2023 23:02 #264778
by saquzi
7i97+7i85 bit file was created by saquzi
Hi, would it be possible to get a bit file for this combination? I actually only needed more sserial for all of the 8i20 amps that i have, and thought that the 7i85 would work and that I would propably run out of encoder inputs before the sserial so therefore I did not pick the 7i74..But now I came to understand that there does not seem to be that kind of bit file available. If the right bit file can't be done, (I'd appreciate quick response to can it be done or not so i know if i have to order or wait for the right file) I just have to order the 7i74 too
- Thank you received: 5334
18 Feb 2023 23:28 #264780
Replied by PCW on topic 7i97+7i85 bit file
- saquzi
19 Feb 2023 15:40 #264810
by saquzi
Replied by saquzi on topic 7i97+7i85 bit file
Thank you
I loaded that bitfile, but I can't find the additional sserial or encoder inputs in command line or in halshow... I have power to the 7i85.. idc26 to db25 cable checked with multimeter and all seems to be ok.
19 Feb 2023 15:53 #264814
did you power cycle the 7I97?
- saquzi
19 Feb 2023 19:10 #264823
by saquzi
Yes i have power cycled it couple of times after that.
19 Feb 2023 22:08 #264832
I'll check on a 7I97 Monday.
- Tesremos
- Thank you received: 10
20 Feb 2023 02:30 #264845
by Tesremos
Replied by Tesremos on topic 7i97+7i85 bit file
was there any update on this?
im using the same config and bit file, but cannoth seem to get the sserial cards talking.
20 Feb 2023 16:06 #264877
what does
mesaflash --device 7i97 --addr [card_IP_address] --readhmid
report?
report?
- saquzi
20 Feb 2023 23:19 #264915
by saquzi
saquzi@debian:~$ mesaflash --device 7i97 --addr 10.10.10.10 --readhmid
Configuration Name: HOSTMOT2
BoardName : MESA7I97
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 3
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 3 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 6 of MuxedQCount in configuration
Version: 4
Registers: 5
BaseAddress: 3600
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: PWM
There are 6 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4100
ClockFrequency: 200.000 MHz
Module: SSR
There are 1 of SSR in configuration
Version: 0
Registers: 2
BaseAddress: 7D00
Module: InMux
There are 1 of InMux in configuration
Version: 0
Registers: 5
BaseAddress: 8000
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for TB1/TB2/TB3
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
TB3-4 0 IOPort PWM 0 PWM (Out)
TB3-8 1 IOPort PWM 1 PWM (Out)
TB3-12 2 IOPort PWM 2 PWM (Out)
TB3-16 3 IOPort PWM 3 PWM (Out)
TB3-20 4 IOPort PWM 4 PWM (Out)
TB3-20 5 IOPort PWM 4 /Enable (Out)
TB3-24 6 IOPort PWM 5 PWM (Out)
TB3-24 7 IOPort PWM 5 /Enable (Out)
TB3-4,8,12,16 8 IOPort PWM 0 /Enable (Out)
TB1-1,2,9,10 9 IOPort MuxedQCount 0 MuxQ-A (In)
TB1-4,5,12,13 10 IOPort MuxedQCount 0 MuxQ-B (In)
TB1-7,8,15,16 11 IOPort MuxedQCount 0 MuxQ-IDX (In)
TB1-17,18,TB2 1,2 12 IOPort MuxedQCount 1 MuxQ-A (In)
TB1-20,21,TB2-4,5 13 IOPort MuxedQCount 1 MuxQ-B (In)
TB1-23,24,TB2-7,8 14 IOPort MuxedQCount 1 MuxQ-IDX (In)
TB2-9,10,17,18 15 IOPort MuxedQCount 2 MuxQ-A (In)
TB2-12,13,20,21 16 IOPort MuxedQCount 2 MuxQ-B (In)
IO Connections for TB4/TB5
TB2-15,16,23,24 17 IOPort MuxedQCount 2 MuxQ-IDX (In)
Internal-EncMux 18 IOPort MuxedQCountSel 0 MuxSel0 (Out)
TB5-13,14 19 IOPort SSR 0 Out-00 (Out)
TB5-15,16 20 IOPort SSR 0 Out-01 (Out)
TB5-17,18 21 IOPort SSR 0 Out-02 (Out)
TB5-19,20 22 IOPort SSR 0 Out-03 (Out)
TB5-21,22 23 IOPort SSR 0 Out-04 (Out)
TB5-23,24 24 IOPort SSR 0 Out-05 (Out)
Internal 25 IOPort SSR 0 AC Ref (Out)
Internal 26 IOPort InMux 0 Addr0 (Out)
Internal 27 IOPort InMux 0 Addr1 (Out)
Internal 28 IOPort InMux 0 Addr2 (Out)
Internal 29 IOPort InMux 0 Addr3 (Out)
Internal 30 IOPort InMux 0 Data0 (In)
TB4-15,16 31 IOPort SSerial 0 RXData0 (In)
TB4-17,18 32 IOPort SSerial 0 TXData0 (Out)
Internal-TXEn 33 IOPort SSerial 0 TXEn0 (Out)
IO Connections for P1
P1-01/DB25-01 34 IOPort None
P1-02/DB25-14 35 IOPort None
P1-03/DB25-02 36 IOPort None
P1-04/DB25-15 37 IOPort None
P1-05/DB25-03 38 IOPort None
P1-06/DB25-16 39 IOPort None
P1-07/DB25-04 40 IOPort None
P1-08/DB25-17 41 IOPort None
P1-09/DB25-05 42 IOPort None
P1-11/DB25-06 43 IOPort None
P1-13/DB25-07 44 IOPort None
P1-15/DB25-08 45 IOPort None
P1-17/DB25-09 46 IOPort None
P1-19/DB25-10 47 IOPort None
P1-21/DB25-11 48 IOPort None
P1-23/DB25-12 49 IOPort None
P1-25/DB25-13 50 IOPort None
FPGA Size: 9 KGates
FPGA Pins: 144
IDROM Type: 3
Module: DPLL
Version: 0
Registers: 7
BaseAddress: 7000
Module: WatchDog
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
Version: 4
Registers: 5
BaseAddress: 3600
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
Version: 0
Registers: 6
BaseAddress: 5B00
Module: PWM
Version: 0
Registers: 5
BaseAddress: 4100
Module: SSR
Version: 0
Registers: 2
BaseAddress: 7D00
Module: InMux
Version: 0
Registers: 5
BaseAddress: 8000
Module: LED
Version: 0
Registers: 1
BaseAddress: 0200
20 Feb 2023 23:55 - 20 Feb 2023 23:58 #264920
Sounds like something went wrong with programming the card:
I get this:
Ahh but I do see an issue with the encoders. I will fix that this evening
I get this:
Last edit: 20 Feb 2023 23:58 by PCW.
Time to create page: 0.145 seconds
