7i97+7i85 bit file
21 Feb 2023 02:04 #264931 by PCW
Replied by PCW on topic 7i97+7i85 bit file
7i97+7I85 with fixed encoders (0..5 on 7I95, 6..9 on 7I85)
File Name: 7i97_7i85d...2-20.zip
File Size:124 KB
21 Feb 2023 08:03 #264933 by craigs711btm
Replied by craigs711btm on topic 7i97+7i85 bit file
BoardName : MESA7I97
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 3
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 3 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 10 of MuxedQCount in configuration
Version: 4
Registers: 5
BaseAddress: 3600
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: PWM
There are 6 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4100
ClockFrequency: 200.000 MHz
Module: SSR
There are 1 of SSR in configuration
Version: 0
Registers: 2
BaseAddress: 7D00
Module: InMux
There are 1 of InMux in configuration
Version: 0
Registers: 5
BaseAddress: 8000
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for TB1/TB2/TB3 -> 7I97_0
Pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
TB3-4 0 IOPort PWM 0 PWM (Out)
TB3-8 1 IOPort PWM 1 PWM (Out)
TB3-12 2 IOPort PWM 2 PWM (Out)
TB3-16 3 IOPort PWM 3 PWM (Out)
TB3-20 4 IOPort PWM 4 PWM (Out)
TB3-20 5 IOPort PWM 4 /Enable (Out)
TB3-24 6 IOPort PWM 5 PWM (Out)
TB3-24 7 IOPort PWM 5 /Enable (Out)
TB3-4,8,12,16 8 IOPort PWM 0 /Enable (Out)
TB1-1,2,9,10 9 IOPort MuxedQCount 0 MuxQ-A (In)
TB1-4,5,12,13 10 IOPort MuxedQCount 0 MuxQ-B (In)
TB1-7,8,15,16 11 IOPort MuxedQCount 0 MuxQ-IDX (In)
TB1-17,18,TB2 1,2 12 IOPort MuxedQCount 1 MuxQ-A (In)
TB1-20,21,TB2-4,5 13 IOPort MuxedQCount 1 MuxQ-B (In)
TB1-23,24,TB2-7,8 14 IOPort MuxedQCount 1 MuxQ-IDX (In)
TB2-9,10,17,18 15 IOPort MuxedQCount 2 MuxQ-A (In)
TB2-12,13,20,21 16 IOPort MuxedQCount 2 MuxQ-B (In)
IO Connections for TB4/TB5 -> 7I97_1
TB2-15,16,23,24 17 IOPort MuxedQCount 2 MuxQ-IDX (In)
Internal-EncMux 18 IOPort MuxedQCountSel 0 MuxSel0 (Out)
TB5-13,14 19 IOPort SSR 0 Out-00 (Out)
TB5-15,16 20 IOPort SSR 0 Out-01 (Out)
TB5-17,18 21 IOPort SSR 0 Out-02 (Out)
TB5-19,20 22 IOPort SSR 0 Out-03 (Out)
TB5-21,22 23 IOPort SSR 0 Out-04 (Out)
TB5-23,24 24 IOPort SSR 0 Out-05 (Out)
Internal 25 IOPort SSR 0 AC Ref (Out)
Internal 26 IOPort InMux 0 Addr0 (Out)
Internal 27 IOPort InMux 0 Addr1 (Out)
Internal 28 IOPort InMux 0 Addr2 (Out)
Internal 29 IOPort InMux 0 Addr3 (Out)
Internal 30 IOPort InMux 0 Data0 (In)
TB4-15,16 31 IOPort SSerial 0 RXData0 (In)
TB4-17,18 32 IOPort SSerial 0 TXData0 (Out)
Internal-TXEn 33 IOPort SSerial 0 TXEn0 (Out)
IO Connections for P1 -> 7I97_2
P1-01/DB25-01 34 IOPort SSerial 0 RXData5 (In)
P1-02/DB25-14 35 IOPort SSerial 0 TXData5 (Out)
P1-03/DB25-02 36 IOPort SSerial 0 RXData4 (In)
P1-04/DB25-15 37 IOPort SSerial 0 TXData4 (Out)
P1-05/DB25-03 38 IOPort SSerial 0 RXData3 (In)
P1-06/DB25-16 39 IOPort SSerial 0 TXData3 (Out)
P1-07/DB25-04 40 IOPort SSerial 0 RXData2 (In)
P1-08/DB25-17 41 IOPort SSerial 0 TXData2 (Out)
P1-09/DB25-05 42 IOPort SSerial 0 RXData1 (In)
P1-11/DB25-06 43 IOPort SSerial 0 TXData1 (Out)
P1-13/DB25-07 44 IOPort MuxedQCountSel 0 MuxSel0 (Out)
P1-15/DB25-08 45 IOPort MuxedQCount 0 MuxQ-A (In)
P1-17/DB25-09 46 IOPort MuxedQCount 0 MuxQ-B (In)
P1-19/DB25-10 47 IOPort MuxedQCount 0 MuxQ-IDX (In)
P1-21/DB25-11 48 IOPort MuxedQCount 1 MuxQ-A (In)
P1-23/DB25-12 49 IOPort MuxedQCount 1 MuxQ-B (In)
P1-25/DB25-13 50 IOPort MuxedQCount 1 MuxQ-IDX (In)
21 Feb 2023 08:56 #264941 by Tesremos
Replied by Tesremos on topic 7i97+7i85 bit file
Wahhoo we have encoder action now! will test SSerial soon! :)
21 Feb 2023 10:06 #264944 by craigs711btm
Okay, so still no SSerial action.
loadrt hm2_eth board_ip="192.168.1.121" config=" num_encoders=10 num_pwmgens=6 num_stepgens=0 num_sserials=1 sserial_port_0=0011xxxx"
the config is 7i97 - 7i85
with 2x 7i84 connected to sserial port 0 and 1 on the 7i85
vfield and vin are conencted and powered on the 7i84's, and have confirmed the 7i85 is communicating by attaching encoders to it and ensuring they read out in halshow.
where do i go from here? is my hal string correct for the sserial?
TIA
21 Feb 2023 11:12 #264945 by saquzi
Replied by saquzi on topic 7i97+7i85 bit file
loadrt hm2_eth board_ip="10.10.10.10" config="num_encoders=6 num_pwmgens=0 sserial_port_0=0011xxxx"
It seems that now i have atleast sserial working on the 7i85, it drives the servo through 8i20 But I don't see the additional encoders or sserial in hal show? I think that it is because of the "sserial_port_0=0011xxxx"" is wrong at me, havent found yet how it should be.
21 Feb 2023 11:21 #264946 by Tesremos
youd want num_encoder=10
22 Feb 2023 16:39 #265038 by saquzi
Atleast first three encoder inputs and sserial works now at the 7i85, thanks!
22 Feb 2023 21:17 #265069 by Tesremos
we still cannot get SSerial to work :(
can you share a txt with the output of your readhmid ? so i can compare vs what we get?
and a out put of your mesaflash --device 7i97 --sserial aswell
26 Feb 2023 19:26 #265433 by craigs711btm
Can anyone shed any light on this
We still can't get the 7i84s to connect
26 Feb 2023 20:03 #265434 by PCW
Perhaps CAT5/6 cable wiring?
Moderators: PCW, jmelson
Time to create page: 0.215 seconds
