7i97+7i85 bit file
3 years 8 months ago #264941 by Tesremos
Replied by Tesremos on topic 7i97+7i85 bit file
Wahhoo we have encoder action now! will test SSerial soon! :)
3 years 8 months ago #264944 by craigs711btm
Replied by craigs711btm on topic 7i97+7i85 bit file
Okay, so still no SSerial action.
loadrt hm2_eth board_ip="192.168.1.121" config=" num_encoders=10 num_pwmgens=6 num_stepgens=0 num_sserials=1 sserial_port_0=0011xxxx"
the config is 7i97 - 7i85
with 2x 7i84 connected to sserial port 0 and 1 on the 7i85
vfield and vin are conencted and powered on the 7i84's, and have confirmed the 7i85 is communicating by attaching encoders to it and ensuring they read out in halshow.
where do i go from here? is my hal string correct for the sserial?
TIA
3 years 8 months ago #264945 by saquzi
Replied by saquzi on topic 7i97+7i85 bit file
loadrt hm2_eth board_ip="10.10.10.10" config="num_encoders=6 num_pwmgens=0 sserial_port_0=0011xxxx"
It seems that now i have atleast sserial working on the 7i85, it drives the servo through 8i20image missing /media/kunena/emoticons/smile.png But I don't see the additional encoders or sserial in hal show? I think that it is because of the "sserial_port_0=0011xxxx"" is wrong at me, havent found yet how it should be.
3 years 8 months ago #264946 by Tesremos
youd want num_encoder=10
3 years 8 months ago #265038 by saquzi
Atleast first three encoder inputs and sserial works now at the 7i85, thanks!
3 years 8 months ago #265069 by Tesremos
we still cannot get SSerial to work :(
can you share a txt with the output of your readhmid ? so i can compare vs what we get?
and a out put of your mesaflash --device 7i97 --sserial aswell
Moderators: PCW, jmelson
Time to create page: 0.105 seconds
