7i97+7i85 bit file
3 years 8 months ago #264845 by Tesremos
Replied by Tesremos on topic 7i97+7i85 bit file
was there any update on this?
im using the same config and bit file, but cannoth seem to get the sserial cards talking.
3 years 8 months ago #264877 by PCW
Replied by PCW on topic 7i97+7i85 bit file
what does
mesaflash --device 7i97 --addr [card_IP_address] --readhmid
report?
3 years 8 months ago #264915 by saquzi
Replied by saquzi on topic 7i97+7i85 bit file
saquzi@debian:~$ mesaflash --device 7i97 --addr 10.10.10.10 --readhmid
Configuration Name: HOSTMOT2
  BoardName : MESA7I97
  FPGA Size: 9 KGates
  FPGA Pins: 144
  Number of IO Ports: 3
  Width of one I/O port: 17
  Clock Low frequency: 100.0000 MHz
  Clock High frequency: 200.0000 MHz
  IDROM Type: 3
  Instance Stride 0: 4
  Instance Stride 1: 64
  Register Stride 0: 256
  Register Stride 1: 256
Modules in configuration:
  Module: DPLL
  There are 1 of DPLL in configuration
  Version: 0
  Registers: 7
  BaseAddress: 7000
  ClockFrequency: 100.000 MHz
  Register Stride: 256 bytes
  Instance Stride: 4 bytes
  Module: WatchDog
  There are 1 of WatchDog in configuration
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  Module: IOPort
  There are 3 of IOPort in configuration
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: MuxedQCount
  There are 6 of MuxedQCount in configuration
  Version: 4
  Registers: 5
  BaseAddress: 3600
  Module: MuxedQCountSel
  There are 1 of MuxedQCountSel in configuration
  Version: 0
  Registers: 0
  BaseAddress: 0000
  Module: SSerial
  There are 1 of SSerial in configuration
  Version: 0
  Registers: 6
  BaseAddress: 5B00
  Instance Stride: 64 bytes
  Module: PWM
  There are 6 of PWM in configuration
  Version: 0
  Registers: 5
  BaseAddress: 4100
  ClockFrequency: 200.000 MHz
  Module: SSR
  There are 1 of SSR in configuration
  Version: 0
  Registers: 2
  BaseAddress: 7D00
  Module: InMux
  There are 1 of InMux in configuration
  Version: 0
  Registers: 5
  BaseAddress: 8000
  Module: LED
  There are 1 of LED in configuration
  Version: 0
  Registers: 1
  BaseAddress: 0200
Configuration pin-out:
IO Connections for TB1/TB2/TB3
Pin#                  I/O   Pri. func    Sec. func       Chan      Pin func        Pin Dir
TB3-4                   0   IOPort       PWM              0        PWM             (Out)
TB3-8                   1   IOPort       PWM              1        PWM             (Out)
TB3-12                  2   IOPort       PWM              2        PWM             (Out)
TB3-16                  3   IOPort       PWM              3        PWM             (Out)
TB3-20                  4   IOPort       PWM              4        PWM             (Out)
TB3-20                  5   IOPort       PWM              4        /Enable         (Out)
TB3-24                  6   IOPort       PWM              5        PWM             (Out)
TB3-24                  7   IOPort       PWM              5        /Enable         (Out)
TB3-4,8,12,16           8   IOPort       PWM              0        /Enable         (Out)
TB1-1,2,9,10            9   IOPort       MuxedQCount      0        MuxQ-A          (In)
TB1-4,5,12,13          10   IOPort       MuxedQCount      0        MuxQ-B          (In)
TB1-7,8,15,16          11   IOPort       MuxedQCount      0        MuxQ-IDX        (In)
TB1-17,18,TB2 1,2      12   IOPort       MuxedQCount      1        MuxQ-A          (In)
TB1-20,21,TB2-4,5      13   IOPort       MuxedQCount      1        MuxQ-B          (In)
TB1-23,24,TB2-7,8      14   IOPort       MuxedQCount      1        MuxQ-IDX        (In)
TB2-9,10,17,18         15   IOPort       MuxedQCount      2        MuxQ-A          (In)
TB2-12,13,20,21        16   IOPort       MuxedQCount      2        MuxQ-B          (In)
IO Connections for TB4/TB5
TB2-15,16,23,24        17   IOPort       MuxedQCount      2        MuxQ-IDX        (In)
Internal-EncMux        18   IOPort       MuxedQCountSel   0        MuxSel0         (Out)
TB5-13,14              19   IOPort       SSR              0        Out-00          (Out)
TB5-15,16              20   IOPort       SSR              0        Out-01          (Out)
TB5-17,18              21   IOPort       SSR              0        Out-02          (Out)
TB5-19,20              22   IOPort       SSR              0        Out-03          (Out)
TB5-21,22              23   IOPort       SSR              0        Out-04          (Out)
TB5-23,24              24   IOPort       SSR              0        Out-05          (Out)
Internal               25   IOPort       SSR              0        AC Ref          (Out)
Internal               26   IOPort       InMux            0        Addr0           (Out)
Internal               27   IOPort       InMux            0        Addr1           (Out)
Internal               28   IOPort       InMux            0        Addr2           (Out)
Internal               29   IOPort       InMux            0        Addr3           (Out)
Internal               30   IOPort       InMux            0        Data0           (In)
TB4-15,16              31   IOPort       SSerial          0        RXData0         (In)
TB4-17,18              32   IOPort       SSerial          0        TXData0         (Out)
Internal-TXEn          33   IOPort       SSerial          0        TXEn0           (Out)
IO Connections for P1
P1-01/DB25-01          34   IOPort       None
P1-02/DB25-14          35   IOPort       None
P1-03/DB25-02          36   IOPort       None
P1-04/DB25-15          37   IOPort       None
P1-05/DB25-03          38   IOPort       None
P1-06/DB25-16          39   IOPort       None
P1-07/DB25-04          40   IOPort       None
P1-08/DB25-17          41   IOPort       None
P1-09/DB25-05          42   IOPort       None
P1-11/DB25-06          43   IOPort       None
P1-13/DB25-07          44   IOPort       None
P1-15/DB25-08          45   IOPort       None
P1-17/DB25-09          46   IOPort       None
P1-19/DB25-10          47   IOPort       None
P1-21/DB25-11          48   IOPort       None
P1-23/DB25-12          49   IOPort       None
P1-25/DB25-13          50   IOPort       None
3 years 8 months ago - 3 years 8 months ago #264920 by PCW
Sounds like something went wrong with  programming the card:
I get this:
File Name: 7i97_7i85d.txt
File Size:7.11 KB
Ahh but I do see an issue with the encoders. I will fix that this evening
Last edit: 3 years 8 months ago by PCW.
3 years 8 months ago #264931 by PCW
7i97+7I85 with fixed encoders (0..5 on 7I95, 6..9 on 7I85)
File Name: 7i97_7i85d...2-20.zip
File Size:123.54 KB
3 years 8 months ago #264933 by craigs711btm
Replied by craigs711btm on topic 7i97+7i85 bit file
FPGA Size: 9 KGates
FPGA Pins: 144
IDROM Type: 3
Module: DPLL
Version: 0
Registers: 7
BaseAddress: 7000
Module: WatchDog
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 10 of MuxedQCount in configuration
Version: 4
Registers: 5
BaseAddress: 3600
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
Version: 0
Registers: 6
BaseAddress: 5B00
Module: PWM
Version: 0
Registers: 5
BaseAddress: 4100
Module: SSR
Version: 0
Registers: 2
BaseAddress: 7D00
Module: InMux
Version: 0
Registers: 5
BaseAddress: 8000
Module: LED
Version: 0
Registers: 1
BaseAddress: 0200
IO Connections for TB1/TB2/TB3 -> 7I97_0
Pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
IO Connections for TB4/TB5 -> 7I97_1
IO Connections for P1 -> 7I97_2
P1-01/DB25-01 34 IOPort SSerial 0 RXData5 (In)
P1-02/DB25-14 35 IOPort SSerial 0 TXData5 (Out)
P1-03/DB25-02 36 IOPort SSerial 0 RXData4 (In)
P1-04/DB25-15 37 IOPort SSerial 0 TXData4 (Out)
P1-05/DB25-03 38 IOPort SSerial 0 RXData3 (In)
P1-06/DB25-16 39 IOPort SSerial 0 TXData3 (Out)
P1-07/DB25-04 40 IOPort SSerial 0 RXData2 (In)
P1-08/DB25-17 41 IOPort SSerial 0 TXData2 (Out)
P1-09/DB25-05 42 IOPort SSerial 0 RXData1 (In)
P1-11/DB25-06 43 IOPort SSerial 0 TXData1 (Out)
P1-13/DB25-07 44 IOPort MuxedQCountSel 0 MuxSel0 (Out)
P1-15/DB25-08 45 IOPort MuxedQCount 0 MuxQ-A (In)
P1-17/DB25-09 46 IOPort MuxedQCount 0 MuxQ-B (In)
P1-19/DB25-10 47 IOPort MuxedQCount 0 MuxQ-IDX (In)
P1-21/DB25-11 48 IOPort MuxedQCount 1 MuxQ-A (In)
P1-23/DB25-12 49 IOPort MuxedQCount 1 MuxQ-B (In)
P1-25/DB25-13 50 IOPort MuxedQCount 1 MuxQ-IDX (In)
Moderators: PCW, jmelson
Time to create page: 0.116 seconds
