Mesa 6i25 pc will not boot
- Dee436
- Thank you received: 13
27 Feb 2023 19:51 #265512
by Dee436
Mesa 6i25 pc will not boot was created by Dee436
I have an issue with my 6i25 card that I bought a few years ago when I was in the US, I bought it as a plug and go kit with a 7i76. I did reference this issue in a previous post about a PlasmaC issue, as I am still having issue with the card I am making this post.
The 6i25 from new always required a few restarts of the host computer to get it to boot, I had put this down to the pc and just basically lived with it. The pc eventually gave up altogether and I got a new motherboard for it. With the new motherboard I was unable to get the pc to boot at all with the 6i25 card installed. I got another pc of a different make and still have the same issue of not booting unless I remove the 6i25.
When the card is in the PCIe 1 slot, the pc gets stuck in a loop of starting shutting down and restarting, if it is in the pcie 16x slot, the pc stays on but seems to be pre post, the 2 red leds on the 6i25 flash and there is no monitor output or hd access, very similar to how the card was from day 1.
Is there anything I can do? Does the card have any software that may have been updated since I bought it in early 2016? are there any tests I can do to check what is happening?
I have been using a 7i76e to keep the plasma running but I need that for the milling machine it was bought for.
I know the simple option would be to buy another 7i76e but esurplus are out of stock and I am U.K. based now.
- Thank you received: 5334
27 Feb 2023 20:33 #265514
Replied by PCW on topic Mesa 6i25 pc will not boot
Is the 6I25 jumpered for 33 MHz?
Have you tried to update your PC BIOS to the latest?
- Dee436
27 Feb 2023 20:44 #265516
by Dee436
Replied by Dee436 on topic Mesa 6i25 pc will not boot
Hi
Yes it’s set to 33 and both pc’s were tried with their original bios and then both updated to the latest bios available. I also went through all the bios settings, also removed all other cards from the pc’s etc etc
- Dee436
28 Feb 2023 15:06 #265567
by Dee436
I have just thought of a possible option, could anyone who is using a 6i25 with no issues, help me with which bios and what version they are using, I can then try source another pc
28 Feb 2023 19:01 #265596
I'll check what MBs it works on here.
The following user(s) said Thank You: Dee436
- Dee436
28 Feb 2023 19:24 #265600
by Dee436
That would be great, thank you
28 Feb 2023 21:36 #265618
A quick check with MB/Systems I have around:
ASROCK J3355B-ITX OK
ASUS A68N-5000 OK
GIGABYTE H81-D3 OK
GIGABYTE H97M-PRO OK
DELL OPTIPLEX 9020 OK
LENOVO THINKSERVER TS140 OK
ASUS A68N-5000 OK
GIGABYTE H81-D3 OK
- Dee436
01 Mar 2023 18:57 #265667
by Dee436
Thanks for the list. There are a few on eBay so will try get one. Fingers crossed it works, will update the post either way.
- JohnnyCNC
- Thank you received: 115
01 Mar 2023 22:42 #265681
by JohnnyCNC
Replied by JohnnyCNC on topic Mesa 6i25 pc will not boot
I'm running a BAT-I J1800 ITX
AMI BIOS with 64Mb SPI Flash ROM
with the same MESA boards with no problems.
I believe this board has been discontinued.
01 Mar 2023 23:09 #265684
Yes I forgot, it also works on the Gigabyte J1800N-DH2
Time to create page: 3.598 seconds
