Mesa 6i25 pc will not boot
25 Mar 2023 10:34 #267460 by Dee436
Replied by Dee436 on topic Mesa 6i25 pc will not boot
After Andy kindly tested my 6i25on his working system, it turns out the card is not working.
So I can at least stop buying pc’s and keep an eye out for a used 6i25 or 5i25, or maybe start out from scratch with a different card altogether.
  • Moderator
  • Moderator
25 Mar 2023 11:05 - 25 Mar 2023 11:06 #267464 by tommylight
Replied by tommylight on topic Mesa 6i25 pc will not boot
Just to be sure, did you try cleaning the connector pins?
Use IPA and a used but clean towel.
New towels shed to much...
Edit,
Also, changing the power supply on that PC is a good idea, if you are sure there was no miss wiring.
Last edit: 25 Mar 2023 11:06 by tommylight. Reason: more info
25 Mar 2023 11:41 #267465 by Dee436
Hi, the connectors on the card and pc are 100% connecting ok
The card has been in 4 of my PC’s and Andypugh also tested on his working system, It is defo dead unfortunately.
I have put a wanted add on the forum for a replacement or alternative to go to Ethernet based solution
Moderators: PCW, jmelson
Time to create page: 0.087 seconds
