7i96 issue read/write
3 years 7 months ago #266031 by evengravy
Replied by evengravy on topic 7i96 issue read/write
Along with the NIC I have ordered a new SSD to build a new 2.9 system on Debian 11+ (keeping this install in place for now). I read on www.gnipsel.com/linuxcnc/debian-11-emc.html that the 5.10-18 realtime kernel is most reliable. I expect there is a way I can restrict synapsis to installing just that version?
I also have been reading around the subject quite a bit, seems that the Realtek NIC's are most problematic (hopefully resolved with the Intel) but Intel NIC's require some tweaking.
Some references which seem to point to mismanagement of NIC drivers in certain kernels:
forum.linuxcnc.org/9-installing-linuxcnc...-realtek-nic?start=0
www.forum.linuxcnc.org/27-driver-boards/...error-finishing-read
github.com/LinuxCNC/linuxcnc/issues/927
More soon. J
3 years 7 months ago #266032 by PCW
Replied by PCW on topic 7i96 issue read/write
I would suggest a 6 series kernel (latest is 6.2-rt3)
The following user(s) said Thank You: evengravy
3 years 7 months ago - 3 years 7 months ago #266033 by evengravy
Right, so that would be just a case of going for the buildbot master branch, then, would it?
Edit: Seems to be covered here, so will try that:
Installing Linuxcnc and Debian Bookworm on problematic hardware -  forum.linuxcnc.org/9-installing-linuxcnc...-realtek-nic?start=0
Last edit: 3 years 7 months ago by evengravy.
3 years 7 months ago #266062 by rodw
Replied by rodw on topic 7i96 issue read/write
My problematic hardware thread uses the 6.1 kernel. I did read somewhere yesterday that intel had made some contributions that improves network performance. Not sure if it has got to the 6.2 kernel yet...
3 years 7 months ago #266101 by evengravy
Okay, perfect. Thanks for the info. The new NIC should be here shortly so I'll get a look more deeply at this over the weekend. I may just try the new NIC as is to see if we get anywhere as the new SSD I have ordered might be some time out yet.
3 years 7 months ago - 3 years 7 months ago #266130 by evengravy
Just as a quick update to this. I dropped the Intel NIC in, after disabling the onboard lan controller in the bios it worked out of the gate without any config. I have test code running atm on the router. So far so good. I understand there are some intel specific tweaks that might be necessary, ill dig those out soon and apply/try them here. I intend to update the 2.9 non the less as I am running one of the earlier releases and haven't updated it for some time so will see how that goes. Ill keep this updated as I test this out. Thanks for the help gents. Hopefully at 20 quid this was a cheap fix
Moderators: PCW, jmelson
Time to create page: 0.070 seconds
