7i76E any updates?
- my1987toyota
- Thank you received: 448
08 Mar 2023 22:15 #266155
by my1987toyota
7i76E any updates? was created by my1987toyota
WOW it is already March . Time flies. I see the 7i76E is still out of stock does anyone know how the new design is going?
Any feature changes like the 7i96S ? is the board layout the same ?
- Thank you received: 5330
09 Mar 2023 01:45 - 09 Mar 2023 01:46 #266169
Replied by PCW on topic 7i76E any updates?
Same layout, differences are sinking, sourcing, or pushpull outputs
(hal settable)
VFD control signals that can do ENA/DIR (as now) and FWD/REV
Better Ethernet ESD protection
(hal settable)
Last edit: 09 Mar 2023 01:46 by PCW.
The following user(s) said Thank You: my1987toyota, DSS
- Thank you received: 7488
09 Mar 2023 03:02 #266178
Either way. very nice feature, thank you.
Replied by tommylight on topic 7i76E any updates?
Single or in sets?..., or pushpull outputs
(hal settable)
- my1987toyota
10 Mar 2023 02:56 #266256
by my1987toyota
correct?
Replied by my1987toyota on topic 7i76E any updates?
That is good to hear. I am guessing it will work for lcnc 2.9 onward but not backward compatable?Same layout
correct?
- my1987toyota
19 Apr 2023 12:18 #269423
by my1987toyota
PCW am I reading your site correct. 7i76e availible ?
- JT
- Thank you received: 593
20 Apr 2023 12:03 #269482
by JT
Replied by JT on topic 7i76E any updates?
It says out of stock...
JT
JT
- my1987toyota
21 Apr 2023 11:29 #269547
by my1987toyota
if it was a case of you had to ask about it first.
the reason for the question is because it also said (limited supply , order one per customer) . I didn't knowIt says out of stock...
JT
21 Apr 2023 18:09 #269571
We had a few older cards will assembly issues that we repaired
after we got parts in (parts we ordered in 2021!)
- my1987toyota
21 Apr 2023 20:18 #269576
by my1987toyota
oh ok I thought it was a limited supply of the new design.
- Thank you received: 4150
21 Apr 2023 20:44 #269579
Replied by rodw on topic 7i76E any updates?
If any Aussies are looking for a 7i76e, I have one I grabbed when it flashed into stock briefly. Also have THCAD-5 and THCAD-10 if you want a plasma package. You can contact me here www.vmn.com.au/contact
Time to create page: 0.255 seconds
