- Thank you received: 5334
Configs made with PNCconf typically only have the debounce delays in custom.hal, almost everything else is in <machine_name>.halCounter mode is set by PlasmaC/QtPlasmaC, so the only change required should be changing the encoder number.
And wiring ...
Edit,
To quick, encoder number must be changed also in the custom.hal file, i think that is where the encoder mode and some other stuff are.
There is no QtAxis PlasmaC that I am aware of.Using PlasmaC or QtAxis PlasmaC or QtPlasmaC?
