7I92TH Help
- kdntool
25 Apr 2023 20:11 #269894
by kdntool
7I92TH Help was created by kdntool
I managed to grenade my 7i92H board. I just received a replacement 7i92TH. I am running Linuxcnc 2.8.0 Debian buster. I tried to update Mesaflash using the steps at the bottom of the GitHub page, and get errors on every step. If I try apt-get install mesaflash, it says I am up to date with 3.4.0.
What would be the best way to update mesaflash so I can flash the new board?
I am still cutting my teeth on Linux, but I can usually figure things out eventually.
Would I be better off just fresh installing a newer version of linuxcnc?
Thank you in advance!!
Ken
Ken
- Thank you received: 7491
25 Apr 2023 21:09 #269896
Replied by tommylight on topic 7I92TH Help
Moved to "driver boards".
- Thank you received: 5334
25 Apr 2023 21:13 #269897
Replied by PCW on topic 7I92TH Help
What errors do you get when you attempt to build mesaflash from source?
- kdntool
25 Apr 2023 21:24 #269899
by kdntool
Replied by kdntool on topic 7I92TH Help
The first step returns "E: Could not get lock /var/lib/dpkg/lock-frontend - open (11: Resource temporarily unavailable)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), is another process using it?"
The second returns "bash: git: command not found"
25 Apr 2023 21:28 - 25 Apr 2023 21:30 #269900
Is it possible you have the package manager open?
askubuntu.com/questions/1109982/e-could-...1-resource-temporari
Last edit: 25 Apr 2023 21:30 by PCW.
- kdntool
25 Apr 2023 21:36 #269901
by kdntool
Yes it was.
Now it returns "
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package pkg-config is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Unable to locate package libpci-dev
E: Unable to locate package libmd-dev
E: Package 'pkg-config' has no installation candidate
E: Unable to locate package build-essential
E: Unable to locate package git
Now it returns "
25 Apr 2023 21:41 - 25 Apr 2023 21:43 #269904
You might try:
sudo apt-get update
first.
Also, what does
uname -a
report?
sudo apt-get update
first.
Also, what does
uname -a
report?
Last edit: 25 Apr 2023 21:43 by PCW.
- kdntool
25 Apr 2023 21:47 #269905
by kdntool
ken@X3MesaCNC:/$ sudo apt-get update
[sudo] password for ken:
Ign:1 cdrom://[Debian GNU/Linux 10 _Buster_ - Official Snapshot amd64 LIVE/INSTALL Binary 20201002-19:09] buster InRelease
Err:2 cdrom://[Debian GNU/Linux 10 _Buster_ - Official Snapshot amd64 LIVE/INSTALL Binary 20201002-19:09] buster Release
Please use apt-cdrom to make this CD-ROM recognized by APT. apt-get update cannot be used to add new CD-ROMs
Hit:3 www.linuxcnc.org buster InRelease
E: The repository 'cdrom://[Debian GNU/Linux 10 _Buster_ - Official Snapshot amd64 LIVE/INSTALL Binary 20201002-19:09] buster Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
25 Apr 2023 21:53 #269907
Weird, it sounds like you don't have network access
- kdntool
25 Apr 2023 22:29 #269911
by kdntool
uname -a returns:
Linux X3MesaCNC 4.19.0-11-rt-amd64 #1 SMP PREEMPT RT Debian 4.19.146-1 (2020-09-17) x86_64 GNU/Linux
Is it possible my hard drive looks like a live CD?
I burned a usb stick with 2.8.4 last night, maybe it would be best to start over?
Time to create page: 0.097 seconds
