7I92TH Help
25 Apr 2023 22:30 #269914 by kdntool
Replied by kdntool on topic 7I92TH Help
I am posting these messages from the same PC so I have network connection
  • Moderator
  • Moderator
25 Apr 2023 22:41 #269915 by tommylight
Replied by tommylight on topic 7I92TH Help
The errors reffering to CD rom are from running a live system, but still that should not disable accessing repositories.
Do you have "software sources" somewhere in the menus?
If yes, open it and uncheck CD rom, enable other stuff there, then in a terminal
sudo apt update
Still, might need to change the repositories there as sometimes the one included just does not work.
If you do not have software sources in the menus,
sudo apt install synaptic
Then open synaptic, on the Settings>Repositories chose some other server and update again.
25 Apr 2023 23:17 #269918 by kdntool
I could not find software sources, but had synaptic installed. I unchecked the cd rom repository. There are only two others to choose. I was able to get the updates for Linuxcnc, but no luck on mesaflash. Do you know what repository I should add to the list?
25 Apr 2023 23:26 #269920 by kdntool
Technically, it would be the repository for the dependency packages:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package pkg-config is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Unable to locate package libpci-dev
E: Unable to locate package libmd-dev
E: Package 'pkg-config' has no installation candidate
E: Unable to locate package build-essential
E: Unable to locate package git
  • Moderator
  • Moderator
25 Apr 2023 23:37 #269922 by tommylight
Yeah, something still not quite OK, it can not find essential packages like git or build-essential.
I would do a new install, hunting this will probably last much, much longer.
25 Apr 2023 23:41 #269923 by kdntool
Will do. Thank you
26 Apr 2023 00:28 #269930 by kdntool
Fresh install did the trick!! Now to convert my old config file to the new system.
Thank you all!!
Moderators: PCW, jmelson
Time to create page: 0.097 seconds
