Network communication fail
- Thank you received: 5326
18 Jul 2023 15:01 #275742
Replied by PCW on topic Network communication fail
I'm curious why ping does not work.
This is what I get for a short test:
sudo chrt 99 ping -i .001 -q 10.10.10.10
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
^C
--- 10.10.10.10 ping statistics ---
7225 packets transmitted, 7224 received, 0.0138408% packet loss, time 7224ms
rtt min/avg/max/mdev = 0.103/0.105/0.123/0.001 ms
^C
- Hannes_P64
24 Jul 2023 12:45 #276150
by Hannes_P64
Replied by Hannes_P64 on topic Network communication fail
I could post more information about my linux but you will have to give me the commands.
linuxcnc version is 2.8.1
I did not build it from source, I downloaded it.
I thought that latency and jitter would not be that critical when using a MESA-card,
but it occures that i was wrong about that.
24 Jul 2023 13:09 - 24 Jul 2023 13:12 #276151
The latency must be good enough so that the communication
time-out limit is not exceeded repeatedly (default timeout limitÂ
is 80% of the servo thread period or 0.8 ms for a 1 ms servo thread)
With a RPI4, I would try:
1. Setting isolcpus to 1,2,3
2. Making sure force_turbo mode is set
3. Run the latency histogram as rmu suggested
4. You may need to increase the servo thread
period to say 2000000 ns (2 ms) with a RPI
Last edit: 24 Jul 2023 13:12 by PCW.
- Hannes_P64
28 Jul 2023 07:56 #276442
by Hannes_P64
Hello dear helpers
I don't want to be too confident now, but I had no more watchdog bite for the
last three evenings.Thanks a lot for your help.
@PCW -thanks for the repeated reference to the isolcpus.
That`s what it took me to understand that you can put it on all three.
In case that anyone has the same problem, I have done the following
1. isolcpus to 1,2,3
2. force_turbo to True
3. WiFi off
servo thread is currently still at 1000000 ns
and the latency was unchanged at first glance,
but i haven't had any failures so far
Thank you a lot for your help and have a nice weekend
Hannes
3. WiFi off
Hannes
Time to create page: 0.462 seconds
