Mesa card 7i90 change pins i/o to defaul as output
- telmoram
18 Aug 2023 13:05 #278366
by telmoram
Mesa card 7i90 change pins i/o to defaul as output was created by telmoram
Good day, please can you help me?, i need change to pins i/0 at power supply start por default in output mode and the logic value to 0.
Thanks.
Thanks.
- Thank you received: 5334
18 Aug 2023 13:30 #278369
Replied by PCW on topic Mesa card 7i90 change pins i/o to defaul as output
Its not really practical, its better to have interface devices be active low.
- telmoram
19 Aug 2023 12:21 #278458
by telmoram
Replied by telmoram on topic Mesa card 7i90 change pins i/o to defaul as output
The interface of the machine (pcb board with optocouplers) uses high logic level to activate the outputs, and the problem that the outputs are activated when starting the system.
- Thank you received: 7491
19 Aug 2023 12:47 #278459
Replied by tommylight on topic Mesa card 7i90 change pins i/o to defaul as output
You can use this:
www.onsemi.com/pdf/datasheet/mc74vhct04a-d.pdf
Or use transistors and resistors as inverters for each output, if you do not need much.
I did just that, made a lot of inverters for a big machine:
forum.linuxcnc.org/show-your-stuff/32784...ofit?start=40#254139
Time to create page: 0.667 seconds
