7i95T errors with Mesa Configuration Tool v2.0.1
- merongi
- Thank you received: 13
15 Sep 2023 22:10 #280891
by merongi
Replied by merongi on topic 7i95T errors with Mesa Configuration Tool v2.0.1
On "Firmware" Tab, there is "Options" Group box.
All three (Step Generators, PWM Generators, Encoders) items are "n/a" and not selectable. I.e. they're not reflecting I/O selected by firmware.
As a result, main.hal has no "num_encoders", "num_pwmgens", num_stepgens" parameters on config string like below.
loadrt [HM2](DRIVER) board_ip=[HM2](ADDRESS) config="sserial_port_0=00000000"
But once I set correct stepper parameters, motor movement was fine without above parameters.
- JT
- Online
- Thank you received: 595
16 Sep 2023 11:48 #280914
by JT
What did you "correct" about the stepper parameters?
I still can't get LinuxCNC 2.10 to run on any of my Debian PC's... how frustrating that is. Seems simple to me to just cherry pick the 7i95T hostmot to 2.9...
JT
Replied by JT on topic 7i95T errors with Mesa Configuration Tool v2.0.1
The num_pwmgens, num_stepgens and num_encoders are only needed in the config line if you want less that all of them... that is a WIP. I'm still trying to sort out how to read the firmware to see the numbers of num_pwmgens, num_stepgens and num_encoders that are in that firmware.On "Firmware" Tab, there is "Options" Group box.
JT
- JT
- Online
18 Sep 2023 17:11 #281097
by JT
I "think" I have the Mesa CT II tool ready to create a fully working configuration for a 7i95T "including" encoder feedback on each axis. If you can test it would help.
JT
JT
- merongi
20 Sep 2023 16:52 #281234
by merongi
I selected TB6600 parameters from MesaCT II as my stepper driver (for temporary setup) is TB6560 but it didn't seem to work. So I copied Sherline parameters that worked with PnCConf into .ini and now motor responds. Over the weekend, I bought an oscilloscope to examine timing and found timing is very relaxed. I may try more optimization later. Now thinking, I can try select Sherline parameters from MesaCT as well. I'll try and report as well when I have a chance. (I'm weekend/night warriors, and things get busy at work.)
- merongi
20 Sep 2023 17:03 - 21 Sep 2023 05:05 #281236
by merongi
My original setup was generic 6040 + parallel port BoB + PC Linux and I'm trying to replace controller with Pi4+7i95T. And encoder feedback is my goal to get accurate cut but I just made Pi4+7i95T work with a motor. I still have to go through Pi4 TTY to control VFD, then I can start work on encoder.
For number of encoder/stepgen/pwm, wouldn't parse HMID read result do the job?
Last edit: 21 Sep 2023 05:05 by merongi.
- Thank you received: 7491
20 Sep 2023 23:24 #281264
Replied by tommylight on topic 7i95T errors with Mesa Configuration Tool v2.0.1
What is 7095T?
You mean 7i95T, most probably.
- merongi
21 Sep 2023 05:05 #281278
by merongi
Sorry it's typo of 7i95T. Fixed the posting.
- Thank you received: 5334
22 Sep 2023 03:23 #281347
Replied by PCW on topic 7i95T errors with Mesa Configuration Tool v2.0.1
The 7I95T is now supported in 2.9 as well as 2.10
- merongi
03 Oct 2023 07:30 #282135
by merongi
There are several issues I wonder how it's to be done.
1. mesact has Joint 0 ~ Joint 5 tabs and it associates them to stepgen00 to stepgen05. Because I'm replacing Parallel port BoB with 7i95T, some wires are not long enough, so I connected X to stepgen 03. In mesact, do I have to use Joint 3?
2. Currently I don't connect encoder to 7i95T yet, but main.hal is written to get positional feedback from encoder. What's the option to turn encoder off and get position feedback from stepper?
3. I connected all home/probe inputs to 7i95T correctly and checked LED light up when switches are closed. mesact writes out ini with corresponding pin info but they're not consumed in neither of main.hal or io.hal. And obviously they're not recognized by Axis. Any comments?
Thanks in advance!
Thanks in advance!
- JT
- Online
03 Oct 2023 10:31 #282150
by JT
1. LinucCNC requires you to use the joints in order starting at 0 and not skipping any joints.
MesaCT allows you to pick any axis for any joint as long as you follow the above.
2. I will have to add the option to ignore the encoder, thanks for that feedback. Probably I'll make it if you leave it blank it will be ignored.
3. I'm not sure what your saying, can you attach the ini file and I'll look.
JT
JT
Time to create page: 0.288 seconds
