7i95T errors with Mesa Configuration Tool v2.0.1
- merongi
- Thank you received: 13
03 Oct 2023 15:50 #282169
by merongi
But it's not used in main.hal or io.hal
main.hal contains only one line for estop
Replied by merongi on topic 7i95T errors with Mesa Configuration Tool v2.0.1
That's my guess too.1. LinucCNC requires you to use the joints in order starting at 0 and not skipping any joints.
Yes. MesaCT allows to pick any axis for any joint. But it doesn't have selection box to choose which stepgen or encoder of the board to the joint.MesaCT allows you to pick any axis for any joint as long as you follow the above.
I think that would do the job nicely. Thanks!2. I will have to add the option to ignore the encoder, thanks for that feedback. Probably I'll make it if you leave it blank it will be ignored.
.INI is generated correctly. It contains all input mapping I put on MesaCT as below snippet.3. I'm not sure what your saying, can you attach the ini file and I'll look.
[INPUTS]
# DO NOT change the inputs they are used by the configuration tool
INPUT_0_16 = Joint 0 Home
INPUT_INVERT_0_16 = False
INPUT_SLOW_0_16 = False
...But it's not used in main.hal or io.hal
# Standard I/O Block - EStop, Etc
# create a signal for the estop loopback
net estop-loopback iocontrol.0.emc-enable-in <= iocontrol.0.user-enable-out
<End of main.hal file> JT
- Trav328
- Thank you received: 31
03 Oct 2023 18:38 #282190
by Trav328
Replied by Trav328 on topic 7i95T errors with Mesa Configuration Tool v2.0.1
I used mesact to generate the files for my 7i95t , i was just wondering the same thing about the Inputs , it generates them in the .ini but not in any of the .hal's
- JT
- Thank you received: 593
04 Oct 2023 10:02 #282262
by JT
Replied by JT on topic 7i95T errors with Mesa Configuration Tool v2.0.1
If you attach your ini file I can recreate your configuration files and see what the issue is.
JT
JT
- JT
04 Oct 2023 11:40 #282272
by JT
I have fixed this and uploaded a new version. I forgot the 7i95T is like the 7i92T and drops the 'T' from the pin names.
So click on Help > Check for Updates then Downloads > Mesa CT PC 64bit. Rpi debs will arrive later today I think.
JT
JT
The following user(s) said Thank You: tommylight, merongi, Trav328
- merongi
05 Oct 2023 03:34 #282332
by merongi
I just cloned git repository and tried 2.0.4
Looks like issue #2 and #3 are fixed!
I still need manual edit to map stepgen to joint due to issue #1
Let me try and feedback if anything doesn't work.
Thank you JT for prompt fix!
Time to create page: 0.182 seconds
